Fuel circuit reassembly on carb rack issue
Discussion in 'XJ Technical Chat' started by Core, Oct 8, 2016.
  1. Core
    Core Active Member
    Switzerland
    I have a strange mechanical/technical problem with reassembling my carb rack
    Carbs are off a XJ900RL
    It is the connector tubes between the carbs that are giving me issues. In particular the sealing of the tubes into the carb bodies.
    I have made a vid showing my issue. Hope it shows what my problem is...
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    It kind of looks like those o rings are flat on the one that doesn't fit. Did you get new o rings?
  3. mlew
    mlew Well-Known Member
    Apex, NC
    I agree, did you replace the orings? Are they the right size?
  4. Polock
    looks to me like even the better fit ones are too loose. look around on here
    http://www.applerubber.com/seal-design-guide/technical-summary/rules-of-thumb.cfm
    the o-ring should compress 10 to 40 %
    you need to measure the bottom of the groove and the cross section of the o-ring and do some math.
    if those used o-rings have been out for awhile they may have shrunk, soak them in gas over night and try that again
  5. Core
    Core Active Member
    Switzerland
    Thanks for the sanity check guys. I had suspected this but the caliper measurements seemed to deny my sanity.
    Infact the overflow T connectors are also quite loose.
    New O Rings it is then.
    I feel it may make sense then to just get a full carb kit seeing that I have them just about right apart at the moment.
    I gather these O rings would be in such a kit.
  6. Toomanybikes
    Tsawwassen bc
    Those orings are not in your off the shelf k&l kits. Click the XJforever icon in top right corner of home page and start conversation with Chacal. He will get you the correct parts pdq, no matter where you are on the planet!
    Jetfixer likes this.
  7. Core
    Core Active Member
    Switzerland
    Thanks mate, onto it already.
    I was looking around on his catalogue threads to see if there are carb kits and what is in them, but there is just too much info!
    I have started a conversation with Chacal now to track down these parts
    many thanks
    Toomanybikes likes this.
