Fuel enrichment screw
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Sep 1, 2016.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    I believe that's the name...u adjust it for color tune... well on carb #1 the top of the threads r gone in carb...I can only turn it in so far so it runs lean...how can I fix this? Helicoil?tap it? Find a new carb?
  2. TheCrazyGnat
    Central PA
    Are you saying the head is stripped, or is part of the screw broken off in there?
  3. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Head is stripped, sorry for bad clarification
  4. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Well just first 2 threads appears
  5. TheCrazyGnat
    Central PA
    Do you have a set of ez outs? That might be easiest, and they are brass, so there is probably a smaller chance that the bit will break off in there.
  6. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Well screw is out..never had an issue with it...just some of the threads r gone in the carb body itself...so if I wanna turn it in I can only turn in so far...can't really adjust the fuel amount currently...
  7. TheCrazyGnat
    Central PA
    Hmm, we'll have to see what others have to say, I don't have any experience with Helicoil or tapping. I don't know that there are different sizes of the adjustment screw available.
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Are you certain the screw isn't bottoming out? Is the tip bent?
  9. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    100% certain..took it out..the threads r jacked up
  10. k-moe
    Start a conversation with Chacal. He carries a thread tap for the idle mixture screw holes. You might be lucky enough to get the threads back into shape by running a tap through (a reformer would be better, but I have not found one in that size). If that dosen't work then you'll need a new carb body. There isn't enough room to use an insert, and having the hole welded shut and re-machined will be eeeeeeeeeexpenssssssve.
  11. MiGhost
    MiGhost Well-Known Member
    These bikes were originally equipped with anti tamper plugs on the mixture screws so there will be a small space at the top without threads. If you can lightly seat the screw and get 4-5 complete turns before the screw comes loose you should be in good shape.
    Make absolute certain that there is not an o-ring or washer still stuck down in the hole. This will cause the spring to bottom out long before your in range for proper mixture adjustment.
    From what I gather. You are saying that the threads in the carb body are stripped out.
    If that is the case. It is easier and cheaper just to replace the carb body.
    ~Ghost
