Fuel line to carb t fitting leak
Discussion in 'XJ Technical Chat' started by jekyllman, Dec 29, 2020.
  1. jekyllman
    jekyllman New Member
    Idaho
    I’ve got a ‘80 XJ650 with carbs that have been driving me crazy. I thought I had poorly adjusted floats. Then leaky gaskets. Then leaky gas line. I think I’ve finally figured out that we’re seeing a leaking t fitting where the gas line enters the carbs. The problem is finding a replacement! Anyone else see this thing leaking? Is there a way to get new O rings for it? Or the part itself? Thanks!
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    don't know about the 650, but my 600, doesn't have any "o" rings on it, the T piece has a rubber coating on it, thats supposed to be a good fit in the sockets, only a new one would rectify any leaks .
    but on a spare set of carbs i renovated, i did force the T piece in with some of the thinnest o rings i could find, and it did hold fuel without leaking, but the set has been on the shelf since, i'm going to swop them onto my 600 ,this coming year,
  4. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    xj4ever -- icon top right of this page.
    HCP2421SET6 Aftermarket Hitachi Buna-N material fuel supply tube O-RINGS, set of 6
    Door dude likes this.
  5. Jetfixer
    To replace seals you will have " break the rack" pull the carbs off the rails separate the carbs , pull the "T" fitting to get to the seals . I bought a BUNA "O" ring kit from Harbor Freight so have plenty of seals. Techinacly these are D rings xj4ever had replacements but so far the Buns O rings have not leaked on my carbs.
  6. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Stick with xj forever. perfect parts ( forevery xj time. )
    Jetfixer likes this.
  7. Toomanybikes
    Tsawwassen bc
    And if you have to change the o rings do the throttle shaft seals while you are there
