Fuel line, what do you use?
Discussion in 'XJ Technical Chat' started by Joseph Newburgh, Jul 8, 2019.
  1. Joseph Newburgh
    Joseph Newburgh New Member
    St paul mn
    Hello I need to know what fuel line to use on my xj 1100, also can I bypass that mickey mouse octy system? Also im confused with my petcock dial, theres the "rib" on it is that supposed to be in the direction of the settings? Off, on pri res, thanks
  2. Timbox
    On my XS1100 I did remove the Octo system, but then you have to play around with the best way to get the fuel line eight straight down from the petcock or over to the other set of carbs. I am guessing your carbs are like mine and there are two sets of two? There is no sharing of the fuel between 1,2 and 3,4 on my bike. So two fuel petcocks, one for each bank.
    This is the Octo[​IMG]DSCN0327 by Tim Brown, on Flickr
    My XS1100 has double down tube petcocks...I don't think yours does? Not that I can see them in your pic above.
    [​IMG]DSCN0332 by Tim Brown, on Flickr
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Rebuild the octy fuel valve, its a safety feature that shuts off gas if the bike falls down. You don't want gas all around you in an accident. Diaphrams are easily available to repair it.
    I use Motion Pro 1/4 black fuel lines on both my XS and XJ11. Its a little pricy but lasts a long time. So far my XS11 is going on 8 years with them. The XJ11 got them 3 years ago. I found that regular 1/4 fuel line at the parts store is too thick and does not bend easily. You will need about 6 feet of line to replace all them.
    The handle on the petcock is the indicator as to what it does. Whatever it covers is what it does, On,off, reserve or prime. There is a right and left petcock don't get the parts mixed up when rebuilding.
    A rebuild kit for both petcocks and octy valve is about 30$.
  4. tradmedic
    tradmedic Member
    When rebuilding my octopus, I ended up crossing the feeds from the petcock to the far side of the bike, after the 'T'. This allowed me room to put in-line fuel filters in without much fuss.
    Timbox likes this.
  5. Timbox
    I was thinking of getting some aftermarket petcocks, run one fuel line between them. Drop the fuel line to the carbs with "T's" at each carb fuel intake. The stock petcocks don't leave much room for fuel lines or clamps.
  6. Joseph Newburgh
    St paul mn
    Thanks guys! Anyone have a oil to run in this 2050? Dino, semi?
  7. mlew
    Apex, NC
    Keep wtith Dino oil, the starter clutch does not like synthetic oil. It make them slip.
  8. XJ550H
    T rex oil all the time shell rotella t4 15 w 40 jaso ma/ma2 rated no motorcycle pic on label to charge extra for
  9. k-moe
  10. Joseph Newburgh
    St paul mn
    Thanks ill hhead to china mart for some shell.
  11. Timbox
    I run T 4 or 5 in all my bikes, have never had a issue. That is a great cheap oil.
  12. Joseph Newburgh
    St paul mn
    Got a oem filter today and 4 qts valve 20 50 bike oil gonna try that.
  13. k-moe
    Just don't put all 4 quarts in. Capacity with the filter change is just a tad shy of 4 quarts.
  14. Joseph Newburgh
    St paul mn
    10--4 little under .5 qt in last bottle, oil was verrrry dirty, shifts runz lots smoother now! Valvoline 2050.
  15. XJ550H
    how much a quart?
  16. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    If it's the same 20w50 valvoline that I'm running, the best price I have found in my area is $4.99 a quart and farm n fleet. It gets over $7 at any auto parts stores that carry it in my area. Worth the 2p minutes to drive to farm n fleet over the less than 5 to advance auto parts
