Fuel Pressure Regulator
Discussion in 'XJ Technical Chat' started by xjyamaha, Oct 21, 2016.
  1. xjyamaha
    xjyamaha Member
    Omaha, NE
    The fuel pressure regulator on my 650 Turbo is in poor shape; I can see rust on the interior. Has anyone ever been able to dismantle one and "refurbish" it?
  2. Toomanybikes
    Tsawwassen bc
    Ask "Hogfiddles "and "K-moe "they are well versed on turbo bikes
  3. k-moe
    I am ?
    Not that well versed. When it comes to the turbos I'm a service-manual mechanic at best.
  4. Toomanybikes
    Tsawwassen bc
    Sorry but you are a wealth of knowledge about many things I assumed you spoke turbo as well
  5. k-moe
    Only about the big picture things. I've never had a Turbo Seca in my garage, nor have I ridden one.
  6. Toomanybikes
    Tsawwassen bc
    Missing quite a treat riding a turbo bike lots of fun in high mountain passes when most bike start to suck wind the turbo ones get faster. First one I rode was in 82, a CX500T had better top speed over 4500 feet and climbing the hills was a rush that felt like you were on level road. I even have the owners manual ,dealer literature book and shop manual
  7. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    I totally agree with this! Going up a mountain, you can totally load the turbo up without exceeding all speed limits (mine is happiest on a flat with about 3psi in top gear doing over 80)
    As far as I know, the regulator isn't disassemblable. I refurbished everything in the fuel system that I could on mine, and that was one thing I had to test and let be. I even installed a fuel pressure sensor just to catch the possibility of a failure. It's a glow shift (cheapy) but is electronic and gives a clear 2psi reading at idle/no boost (unless you forget to open the fuel valve or run out of gas...) and outpaces my boost gauge by 2psi consistently (as consistently as I can stare at that while blasting down the road under boost :rolleyes:).
    The only option I know is to purchase another one that regulates to 2-psi or is adjustable so you can get that mark.
