Gas Shoots Out of Hole
Discussion in 'XJ Technical Chat' started by PhillipXS1100, Jul 8, 2023.
  1. PhillipXS1100
    PhillipXS1100 New Member
    Vernon hills, Illinois
    Hi All,
    on my mikuni BS34 carbs, from the hole at the 7 o'clock position, fuel pours out with engine off. As soon as I turn the petcock ( non vacuum actuator) to the on position, it pours out unabated. Any ideas. I circled the hole on intake side picture. Not doing this from any other carb. The carb in question is 1st carb from left side.
  2. PhillipXS1100
    Hi All,
    on my mikuni BS34 carbs, from the hole at the 7 o'clock position, fuel pours out with engine off. As soon as I turn the petcock ( non vacuum actuator) to the on position, it pours out unabated. Any ideas. I circled the hole on intake side picture. Not doing this from any other carb. The carb in question is 1st carb from left side. image_2495.jpg
  3. Rooster53
    Carb float needle valve stuck open. Could be as simple as tapping on carb to unstick or since we don't know the bike's history the carbs could be in need of a rebuild
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Needle is most likely stuck open. Might get lucky and be able to tap on side of carb bowl to free it up otherwise you'll need to pull carbs and see what is going on.
  5. k-moe
    Yep. Stuck or leaky float needle.
