Gas tank rust
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Sep 27, 2017.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    What's the best most cost effective way to clean inside of it?
    That depends entirely on how bad the rust is, and how soon you want to deal with cleaning it out again. Phosphoric acid is my go-to for most situations.
  3. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    It's not bad and I can do it whenever.. how do you go about phosphoric acid?
  4. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Not super easy to find phosphoric acid around me
  5. Polock
  6. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Thank you.. so do you have to neutralize it somehow after using acid?
  7. Polock
    shake some water around in it, maybe twice then drain it and dry real good. especially the seam, that's where it will stay wet and where most of the rust is. a heat gun works well.
    do you plan on sealing it ?
  8. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Yup I have caswell two part and where is the seam exactly?
  9. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Anyone ever simply poured Evaporust in a tank? I have a moped with a one gal tank full of heavy surface rust. I'm thinking of just filling it up and letting it sit for a day or so.
  10. Polock
    the ridge that runs around the bottom inner edge of the tank. by the fuel valve. where people put the car door edge guard, yuck.
    when you take the fuel valve off, you'll see it
  11. Polock
    guys that restore old tractors seem to like molasses and water mixture. sounds strange but they say is the best for big things
  12. Polock
  13. k-moe
    Discard what I'm recommending then. Follow Caswell's directions EXACTLY. They have a good kit, but proper preperation is vital for it to be successful.
    Evan Hawtrey and Polock like this.
  14. Franz
  15. Polock
    like K-moe said, if you use a kit follow their instructions.
  16. dkavanagh
    Rochester, NY
    I used POR-15 on my XJ550R tank. Coating looks good except for one side of the tank where it seems to have pulled away, but not in in a flap, more of a bubble. I'll have to yank that off sometime so crap doesn't get trapped behind it.
    My recently acquired FZR1000 has some mild rust in much of the tank and a few patches where it looks flaky. In the picture, there's a patch near the sender unit.
    I was thinking either letting MetalRescue sit in the tank for a while and eat the rust away, or this method w/ electrolysis. I'd have to make up electrodes that fit in to the fill cap opening. The negative that's a ring that touches the sides of the opening and the anode that sticks down through the middle. I'd probably 3d-print a spacer to keep everything in place, but allow me to see inside to check the progress.
  17. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Evaporust will work, just have to make sure that all areas stay wet all the time or you will end up with an etch line. If it will hold the stuff, fill it up and let it sit for 8-12 hours and then check it.
    The reason the POR-15 pulled away is from moisture. I had the same problem in my last attempt. My next tank coating will be done after a thorough torching. That urethane is a water-cure poly so if there is any amount of water in leftover rust pores or in seams then it will not adhere, it will set and roll off like rubber.
  18. squidx85
    squidx85 Member
    South Dakota
    Not trying to contradict k-moe but I would be inclined to stay away from using phosphoric acid. I've used it on steel furniture I've built, and while I think the furniture came out beautifully, it was a pain to get all of it off, to get it to stop attacking the metal, even days later.
  19. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    Keep in mind that acid treatment will eat good metal as well as the rust. I’ve used the phosphoric acid treatment and it works well. Follow up with baking soda solution to neutralize.
    I’ve also used electrolysis. It works, too. I found it maybe too much work.
    Metal Rescue or Evaporust are excellent choices for removing some rust from the bottom of the tank. They won’t damage good metal.
    If you’re using the Caswell liner, you can buy 5 lbs of resin rust cutting media at Harbor Freight for pretty cheap. It looks like little green pyramids. Put a couple pounds in it and rotate in the dryer for an hour or two. I put the tank in an old sleeping bag then stuff the drier with pillows. Vacuum out the dust when you’re done. Rinse with alcohol and it’s ready to run or install Caswell.
    Don’t screw up the Caswell liner. I don’t think you can remove that stuff.
    I hope this helps.
  20. k-moe
    Prep, and cleanup both matter when using any treatment. You can't just leave the acid on the metal and expect that it won't keep chooching away. You have to do a throrough clean-water rinse (or rinse with a base as JetmecMarty reccomended).
    The second step of Parkerizing is an acid etch, followed by a hot water bath to rinse the initial acid off.
    The Caswell liner can be removed, but it's a hassle and involves the liberal use of MEK.
    Prep, prep, prep.
    Process, process, process.
    Be thorough.
    Rust is a cat of many skins.
  21. Mike00
    Mike00 New Member
    Southern Illinois
    For de-rusting steel I always use oxalic acid, then after very thorough rinsing, neutralize with a weak sodium carbonate solution and either brushing of in this case alot of sloshing around to make sure it neutralizes the seam.
    It's available pure cheap online. It's in products like "wood bleach" and a comet like cleanser called "Barkeeper's friend" contains it. I'd guess a teaspoon of most laundry detergents would have sodium carbonate or something similar to neutralize but you'd have to check.
  22. Polock
    that's good stuff for bringing old tools back to life, brightens your deck up nice too
    Mike00 likes this.
  23. Timbox
    You will just have to do what feels good for you. Some use harsh acids other us lighter ones. As k-moe and others have said, this take time and attention to detail when you are doing the tank. If you do use a acid product, rinsing and neutralizing the acid is a must. So when you think you have it neutralized hit it again with water or what ever you want to use. I flush my tanks with well water with at least 15 gals when I flush. Flushing it over a 5 gal white bucket to keep an eye on the little bits coming out really helps. So when the bits stop keep flushing for a while.
