Wanted GAUGE CLUSTER REPLACEMENT
Discussion in 'For Sale, Trade/Swap, Wanted' started by Micah Little, Jul 24, 2022.
  1. Micah Little
    Micah Little New Member
    Colorado
    For an '82 750.
  2. Fuller56
    Fuller56 Well-Known Member
    A little more detail of what you need please. I have an atari from a Maxim 750 but the outer housing is cracked. It likely could be repaired. Advise if you are interested and/or want photos. It shows 30k something miles.
  3. Micah Little
    Colorado
    I'm trying to replace the atari with regular gauges. Pretty new to this so unfortunately not sure I know the terminology to use to better convey what I'm looking for.
  4. Toomanybikes
    Tsawwassen bc
    Sound like you want 83 maxim gauges and even the 650 ones will work for you
  5. XJ550H
    the 73 maxim uses the same bracket to mount the cluster as the 650.
    there is also a thread on how to eliminate the atari cluster
    not sure if the mount will fit onto a 82
  6. k-moe
  7. Wingedwheel
    Wingedwheel Member
    MI
    I have a cluster for an 82 650 if that works
  8. Micah Little
    Colorado
    I’d have to defer to the more knowledgeable here if that would work or not. How much would you sell it for?
  9. k-moe
    It will not work, unless that cluster has an electric tachometer.
  10. Micah Little
    Colorado
    Sorry for my ignorance but how can I know if it’s an electric tach?
  11. hogfiddles
    The ‘82-‘83 xj650 maxim cluster, and the ‘83 xj750 maxim clusters ARE electrical tachs..... that’s why they can be used if the harness is modified.
    How can someone tell if the tachs are electric———- just look at the back of the cluster (or the tach if it’s out of the cluster). The electric ones have wires, the mechanical ones have a cable-driven gear-drive that looks just like the back of a speedometer.
  12. Wingedwheel
    Wingedwheel Member
    MI
    It is an electrical tach. The speedo has a cable the tach has a harness.
  13. Wingedwheel
    Wingedwheel Member
    MI
    I don’t know how to post a pic.
  14. hogfiddles
    Then it’s the one you want
