Gear oil
Discussion in 'XJ DIY How-To Instructions' started by Joe34, Sep 29, 2017.
  1. Joe34
    Joe34 Active Member
    Halifax nova scotia
    86 max X
    Not how to but how much.
    How much gear oil should I put in my rear end?
    Can't find anywhere on how much to fill.
    in factory service manual
    Joe34 likes this.
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Common guys....we aren't going to let this pass without a few snarky and semi-obscene comments are we....:eek::rolleyes:o_O
    Joe34 likes this.
  4. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Haha. Yea, good thing this is a bike forum..hahaha guess I had that one cummin to me hahahahaha
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
  6. k-moe
    Put it in until it starts to leak out.
  7. XJ550H
    i was just waiting for the comments....................
  8. XJ550H
    the fill hole or .........
    just not going to go there
  9. cgutz
    SE South Dakota
    MattiThunderrr was who I had in mind...he must not be online today...
  10. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Went to the yam dealer and they gave me yamaha gear oil It is 80 api gl-4 but not hypoid.
    Is this ok?
  11. Joe34
    Joe34 Active Member
    Halifax nova scotia
  12. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    HE'S here, he's just feeling quiet...
  13. k-moe
    GL-4 is a hypoid gear oil.
    Joe34 likes this.
  14. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Thank you. Still learning.
  15. Jeremy Washburn
    Jeremy Washburn New Member
    Kansas City
    I am new to this and I am wondering where do you put the gear oil in on a 1983 xj 750? I haven't had my xj very long and I am still learning.
  16. XJ550H
    hypoid gear oil.
    goes in the hub at the rear axel left side of bike. you will see a vent on top, an oil plug mid hub and bottom of hub. remove the fill plug first so you can check it (if you can not get top plug out do not remove bottom plug until you can remove it)
    drain it from the bottom plug.
    Bugzy and ShootyMcBang like this.
  17. Jeremy Washburn
    Kansas City
    Okay how do I get the top plug out?
  18. XJ550H
    look at photo vent on top , fill at 3:00, drain under hub
  19. Jeremy Washburn
    Kansas City
    Oh okay so you don't remove the vent just the fill plug
  20. XJ550H
    leave vent alone . open fill to check level and add to fill . remove drain to drain.
    if you can't get fill plug out do not drain
    I have to remember to put photo up first to avoid confusion
    Bugzy likes this.
  21. Jeremy Washburn
    Kansas City
  22. Jeremy Washburn
    Kansas City
    I don't know why it double posted the pictures lol I took that side cover off because it was leaking. Is this where gear oil goes?
  23. XJ550H
    If you are talking about the transmission (gearbox) it uses/shares the motor oil which is filled at the oil cap on the clutch cover
    gear oil is for rear end like in a car
    you can edit your post for a few minutes to remove extra photos
    or a moderator can edit out extra photos
  24. Jeremy Washburn
    Kansas City
    Did you see my picture of the cover where the shifter is? That is the one that was leaking. Is that the oil from the engine or gear oil from the final drive?
  25. XJ550H
    that is engine oil . the motor is a one piece unit with the gears inside the motor case uses same sump to supply oil to both sections
    look at this thread for a better understanding of the internals of motor
    XJ750 Engine removal and split - Pictures.
  26. Jeremy Washburn
    Kansas City
    Oh okay thanks for your help everyone on here are always so helpful
  27. Jeremy Washburn
    Kansas City
    I just have one more question when you guys said 80w hypnoid gear oil all I have been seeing is 80-90 is that right?
  28. XJ550H
    yes that works too.
    and to be clear IT does not go in motor just rear hub:rolleyes: at axle
  29. Jeremy Washburn
    Kansas City
    Lol yeah I know I have changed my oil a few times just haven't done anything with the rear drive gear oil.
  30. XJ550H
    I figured that . I sometimes forget that I am not talking to someone but writing things and that is to people with different skill sets and terminology of bike parts.
    I just did it in another post about red warning light forgot about the Atari red warning light and focused on oil light. I just fixed my oil light had to high of a wattage bulb and poor contacrt.
    I have a Atari cluster on my 82 750 maxim
    just like the oil plug on top (but it is not on top just the highest plug) and you saw the vent on top I must be careful not to misdirect and cause people problems
  31. Jeremy Washburn
    Kansas City
    Yeah lol I have been thinking about getting rid of my atari but I don't know if I want to try that yet lol
  32. XJ550H
    I still have and use my original Nintendo deck ......… oh we were talking about speedo tach clusters
  33. Jeremy Washburn
    Kansas City
  34. k-moe
    As an occasional (unfortunately) long-distance rider, I can vouch for the ATARI being a useful device. Even been riding along oblivious of the obvious? Just enjoying the day? Maybe a bit too far from a gas station, and on reserve?
    Ya...warnings help avoid that problem.
    Jetfixer and Jeremy Washburn like this.
  35. Jeremy Washburn
    Kansas City
    Yeah I would agree however I need to figure out why my fuel gauge isn't working. Any idea?
  36. Jetfixer
    Are the wires hooked up to the sending unit under the tank ?
    Jeremy Washburn likes this.
  37. XJ550H
    "sending unit in tank may be bad
  38. k-moe
    The plug for the sending unit is under the seat. Easy to check. White flat plug with two wires coming from directly under the fuel tank.
    Fairly often when I do maintenance that requires that the tank be lifted or removed, I forget to plug it back in.
  39. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    My low fuel light never worked till i pulled the tank for paint, removed the sender and found the little wire inside broken at the solder point. Resolder, fixed! May be that simple.
  40. Jeremy Washburn
    Kansas City
    I haven't been able to check yet. However I rode to work today and on the way home when I turn a corner my bike just died. It started right back up. And did it again when I turned into my driveway and started right up any ideas?
  41. k-moe
    Which direction were you turning in, and how quickly?
  42. Jeremy Washburn
    Kansas City
    To the right both times and around 20 or something like that and the second time was less than that
  43. k-moe
    Check the routing of the wiring harness near the headstock and headlight. Look for a loose plug or worn insulation.
    Chitwood likes this.
  44. Jeremy Washburn
    Kansas City
    You think it's something to do with the headlights wire harness? I did install a led headlight. The bike will start right back up after it dies.
  45. MattiThundrrr
    Turning the bars could wiggle a loose plug connection, or cause a worn wire to contact the frame, causing a short. Once the bars are straightened, the electric faries might be free to roam and perform their magic.
    Jeremy Washburn, Chitwood and k-moe like this.
  46. k-moe
    ^that^. It could also be floats set too low, but that would cause a stall when braking in a straight and when turning in any direction at low speed.
    Jeremy Washburn and Chitwood like this.
  47. Jeremy Washburn
    Kansas City
    Thanks I will update when I get the chance to check it out. Hopefully this weekend
