General compression test question... applies to XJs too
Discussion in 'XJ Technical Chat' started by SQLGuy, Oct 8, 2009.
  1. SQLGuy
    SQLGuy Well-Known Member
    Might be fun, but I'd need to buy a different compressor. Mine only does 110 PSI. The highest pressure on from HF that I found does 175... that still might not be enough to find the real pressure holding capability of the cylinders, but at least it would allow you to evaluate whether the seal is decent.
  2. Polock
  3. wizard
    If you're up that high, maybe you should have a microlight instead of a motorbike. (joke, guy)
