Get old mufflers off
Discussion in 'XJ Technical Chat' started by Plumper, Jun 11, 2019.
  1. Plumper
    Plumper Member
    Taber
    What's the best way of getting mufflers off xj 750 I've loosened the clamp all the way and took the bolt out off the hanger, there pretty rusty but there not even moving at all and I'm hammering the crap out of them,
  2. PJC750
    PJC750 Member
    Northeast
    try an oil filter ratchet at wider end of exhaust for leverage,alternate lift,then press down. Have 2nd person bang opposite end with rubber mallot, shoot some pb blaster around the joint.
  3. k-moe
    1. Dont' hammer the crap out if them.
    2. Penetrating oil up the joint.
    3. Twist and pull, and twist an pull, and twist and push, and repeat to free the (likely rusty) gaskets up.
    4. Be patient. They will come off.
  4. Plumper
    Plumper Member
    Taber
    Ok thanx
  5. PJC750
    PJC750 Member
    Northeast
    At least I got the lube n twisting idea right, no banging Plumper
  6. Plumper
    Plumper Member
    Taber
    No I'm not gonna do that anymore it didn't feel right and I don't wanna brake any other part of the exhaust, I took mufflers off an 83 Honda magna and they giggled right off though maybe there was a hidden clamp or something I wasent seeing on mine but I'm just impatient I guess
  7. Timbox
    The collector side I think has three cut flanges the accept the mufflers. You can take a chisel and try to open them up a little. Don't o crazy but if you open them a little and can get enough penetrating oil in there, they will come off. If you do too much twisting and cranking on the muffler its self, it will brake at the collector to muffler connection point. Old age and rust will make it brake apart.
  8. k-moe
    If the mufflers are so rusted that twisting brakes them, then they are not suitable for reinstallation anyway.
    The collector is the hardest part of the exhaust system to source a replacement for. Saving it is more important than saving a muffler.
  9. Plumper
    Plumper Member
    Taber
    I'm not trying to save the mufflers, and I'm really not trying to brake the collector, my right side muffler has a massive hole in it at the bottom that's why I'm trying to get them off and put on those other ones, I did find where they split at the ends I pryed them open a little and sprayed oil in there gonna try again tonight to get em off
  10. Plumper
    Plumper Member
    Taber
    If they don't loosen up still I was gonna sawzall it off just above the clamp then make a slit with a zip disc on the remaining part and try and spread it open,
  11. PJC750
    PJC750 Member
    Northeast
    I like it, let us know how you make out.
  12. lupz
    lupz New Member
    I've had great success using Wurth Rost off on exhausts in the past.
    Just spray it on let it do its magic and wiggle off.
  13. XJ550H
    Plus, Ice, or Blue Ice? I see it has Teflon in it too.
  14. lupz
    lupz New Member
    Just the Plus version. Seems to penetrate better than the others.
    XJ550H likes this.
  15. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Heat the hell out of the muffler at the joint with a torch till its red, try to wiggle while hot then pour cold water on it, or hose it till cool to the touch. Oil, Heat a bit add Penetrating oil, wiglle.
    If it doesnt go, Repeat process untill it comes off.
    Recommend "real torches" of MAP hand torch, if you only have a hand propane torch, use 2 to heat faster.
    Or grab a map torch theyre super handy.
    Otherwise if your patient and carefull with the zip disc, so you dont put a groove in the inner pipe thats pretty quick too.
    Jetfixer and k-moe like this.
  16. Plumper
    Plumper Member
    Taber
    I do have a torch and map gas, never thought of that, but now I have wd-40 and oil all over is it still a good idea to use a torch? I forgot my sawzall at work like a dumb ass so I'm gonna try again tomorrow
  17. Colin 85 700
    Thunder Bay, ON
    Penetrating oil ist that flammable, it will flare up but blow it out. allways keep a fire extinguisher nearby anytime your using fire stuffs but you should be ok.
    A wet rag or 2 at hand is always welcome
    ..... Plus you should have water near by if your trying my method.... ;)
    Franz likes this.
  18. Plumper
    Plumper Member
    Taber
    So I got the old muffler off, there's another ring on the pipe that was under the clamp part it's metal with a outer shell of thin copper, it's all mangled can I cut that off to and just get another one? Is that just a muffler gasket that I can buy at an auto parts store
  19. k-moe
    That is the gasket, and cutting it out is fine. You won't find one at an auto parts store. Yamaha or Chacal have them, but only one of those sellers will get them to you in three days or less.
  20. Plumper
    Plumper Member
    Taber
    Is there something else I can use instead of that gasket? i tried to put these new mufflers on and that gasket is a little to fat, but if I cut it off they'll fit I could probably fit a thinner gasket in there
  21. XJ550H
    photo please
  22. Plumper
    Plumper Member
    Taber
  23. Plumper
    Plumper Member
    Taber
    As you can see i was already cutting it before asking the question hahaha my bad, but with that old crap on I can't slid my new ones on
  24. Plumper
    Plumper Member
    Taber
    But that gasket makes it 1 3/4" and the pipes my mufflers came off are 1 1/2" and the pipes on my maxim are 1 3/8" so I could use a thinner gasket
  25. XJ550H
    there are gaskets that fit a range of size they have fingers in them so they can compress. reducers
    what were you cutting them with? my guess is a hacksaw line is so straight.
  26. Plumper
    Plumper Member
    Taber
    My zip disc on my grinder
