gouge in shifter cover surface?
Discussion in 'XJ Technical Chat' started by eigenseca, May 30, 2020.
  1. eigenseca
    eigenseca Member
    Arkansas
    So I was scraping away the gasket from the shifter cover and I noticed this angled depression in the surface. I'm pretty certain I didnt do this as I wasn't scraping at an angle like that and I would have felt such a big chunk come off. Is this supposed to be there?
  2. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    can you better highlight the area you're talking about? I can't really tell what you are referencing. thx
  3. eigenseca
    eigenseca Member
    Arkansas
    Sorry about that!
  4. raskal
    So it doesn't appear to cause a situation where fluids could pass, so I'd say it's not a big deal
    if you're worried about it a small dab of RTV would fill the crevice
    if you are super lucky, someone who has way more knowledge of this are will suggest what to do. Let's hope that this thread bump will let them find your thread :)
  5. eigenseca
    eigenseca Member
    Arkansas
    Thanks for the response! I was starting to think the same thing, if its not supposed to be there then there is still some meat left for the gasket to seal the two surfaces.
  6. XJ550H
    it hasn't broken the wall wouldnt worry about it
    eigenseca likes this.
  7. Mezzmo
    Mezzmo Active Member
    Its not supposed to be there, BUT I wouldn't worry about it as it won't be a problem unless its got a crack. It could be built up with TIG and then filed flat but not really worth the hasssle.
    eigenseca and XJ550H like this.
