Greetings and salutations
Discussion in 'Hangout Lounge' started by Deathboner727, Feb 26, 2018.
  1. Deathboner727
    Deathboner727 New Member
    Ohio
    Been browsing the thread and decided to make an account. Working on a 82 XJ750 Maxim. Had problems with boss springs 2 years ago. Cracked the case and replaced. I remember there being a debate on doing this job without cracking the case. NOT POSSIBLE. Any how just wanted to say hi and thank you for all the knowledge on here.
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Bwahaha! Deathboner! Awesome!
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I like the bike. I'm going a similar route, eventually, when life stops getting in my way
  4. Chitwood
    With the way you have it hardtailed, and your comment in another thread, is your swing arm welded solid or can it still pivot on the bearings?
  5. Deathboner727
    Ohio
    Swing arm is still pivot. The back end of the frame was chopped off karate style. Dom tubing was then welded on to the back end. Notched new tubing for axle and welded collars on for axle . I was surprised to see how thin the metal was for the stock frame. The upgraded with the dom is was stronger.
  6. Chitwood
    Good that you went with some heavier tubing but with the swing arm still being able to pivot is likely why the stud broke off on you
