Hard to find neutral after rebuild
Discussion in 'XJ Technical Chat' started by Thrasher, Feb 15, 2018.
  1. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    What transmission components are likely to be bad? It is hard to find neutral after rebuild on a FJ600?
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Fine tuning the clutch cable helps make it easier to find neutral on my XJ.
    k-moe and Toomanybikes like this.
  3. Toomanybikes
    Tsawwassen bc
    Will it shift properly when it's not running? And warped clutch plates will do that also
  4. Jetfixer
    Shift linkage at shift lever may need tweeked.
  5. Thrasher
    Thrasher Member
    No linkage. I think it is shifting forks.
  6. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Like Kmoe always says, pick the low hanging fruit first. I would suggest exhausting all possibilities externally before opening it up if it's necessary
  7. k-moe
    The adjustable linkage (if present on your model, I don't recall if the FJ has one) is external, between the pedal and the shift shaft. The #1 cause for a difficult to find neutral is an improperly adjusted clutch cable. Rickcomatic has an excellent write up on the process for an XJ, which is applicable to the FJ.
    http://www.xjbikes.com/forums/bookmarks/153/view-item
    If there were any internal defects, they would show up while shifting into, or out of, one or more gears.
    Yamaha transmissions of the era are very finicky when it comes to finding neutral; it's very easy to shift right through it and never notice the detent. some people find it easier to shift down from second to reach neutral.
  8. Polock
    same kind of oil as before ?
  9. Thrasher
    Thrasher Member
    It is set up with GP shift, same oil, cable is fine, clutch plates are flat.
