Header pipes would swap or not?
Discussion in 'XJ Technical Chat' started by quebecois59, Mar 5, 2017.
  1. quebecois59
    Hogfiddles wrote a nice an useful thread about fuel tank interchangeability.
    Now I have a question about header pipes interchangeability between the XJ900RL and the XJ750RL, would it be a direct swap or not? What about the collector box?
  2. hogfiddles
    The collector boxes will interchange. They mount at the same point. The front pipes probably won't due to the 750 exhaust ports are not as high as the 900. So, the pipes are a bit shorter.
  3. quebecois59
    Because the stroke is shorter ?
    Yep. 60.5 mm for the 900, 56.4 mm for the 750.
  5. quebecois59
    all right, thank you guys
  6. hogfiddles
    The cylinders aren't as tall… So the head is not as high… So The exhaust ports are not as high
  7. k-moe
    Suddenly I have a Dylan song stuck in my head.
  8. quebecois59
    Which one?
  9. k-moe
    The password is: high.
    TheCrazyGnat and Stumplifter like this.
