headers...?
Discussion in 'XJ Technical Chat' started by First_82_Seca_650, Mar 11, 2012.
  1. First_82_Seca_650
    First_82_Seca_650 New Member
    Obviously this is my first bike, and i don't want to screw anything up too badly, but there are some things that I have to do to get it running...
    One of these is replace the exhaust joint and pipes. Can I remove the exhaust headers to clean them and to mount the new joint and pipes? Or will I have to replace an O-ring or something of the sort?
    Thanx in advance for your help.
  2. skillet
    skillet Active Member
    SW TN
    There is a crush washer between the heads and headers. Hope that's what you're talkin' about???
    skillet
  3. bigfitz52
    Exhaust gaskets: http://xjbikes.com/Forums/viewtopic/t=29356.html
    Those are the ones at the head.
    There are also gaskets within the collector box "spigots" that you'll probably need to replace as well, since you're replacing the collector box.
    Additionally, the collector box-to-frame mounting point incorporates a couple of rubber/metal composite "dampers" that should be replaced; likely the originals are long gone.
    Check with XJ4Ever for everything you'll need.
  4. First_82_Seca_650
    Thanx, guys...
    Both are helpful and exactly what I was referring to.
    Appreciate it.
