HELP! Anyone in the south central PA/north Maryland area?
Discussion in 'XJ Technical Chat' started by jmilliken, May 24, 2011.
  1. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Hey all, is there anyone around the south central PA / northern Maryland willing to help with some tuning and valve check? I don't have the guages, YCIS tool. colortune, or shim tool. I'm a little nervous cracking open the head... I've never went there before. I read bigfitz's s write up on valve clearances... doesn't sound too hard, but I'm just nervous for some reason... I', definitely willing to cover gas money + take care of you... I'm just looking for someone who's been here before and has the tools.
    PS I have PODS on the bike, but I'm kinda indifferent on that subject. I have an airbox, just too lazy to put it back in...
  2. BigT
    BigT Active Member
    Airville, Pa
    Re: HELP! Anyone in the south central PA/north Maryland area
    I also live in York county and I have all of the tools except the colortune, but I do not have much experience. Not sure how much help I would be. Still trying to take care of a lean condition on my bike. Also I am not familiar with the later bikes. Is your bike water cooled with 5 valve heads?
    PM me if you want and maybe try to work something out.
  3. schmuckaholic
    California
    If you've got a 700, then you don't need a YICS tool.
    Zaphod: "Right, computer, I want full control of this ship now."
    Computer: "You got it."
    Trillian: "But can you fly her?"
    Zaphod: "No. Can you?"
    Trillian: "No."
    Zaphod: "Ford?"
    Ford: "No."
    Zaphod: "Fine. We'll do it together."
    If it is indeed an aircooled engine, don't worry -- time consuming, yes, but definitely doable. I had never done it before when I did mine, and it turned out just fine. Come on -- you can do this.
  4. jmilliken
    Dillsburg, PA
    It's the air cooled engine.... why doesn't it need YCIS tool? It is a YCIS engine....
  5. iwingameover
    iwingameover Active Member
    Baltimore here.
    I don't have a colortune, haven't needed it. I can tune fine without one.
    I can borrow a YICS tool if needed, my 81 is non yics.
    You don't take the head off to do the valves. Just the cover.
    If she's rideable and you want to make the trip down I've got the space and the tools. The 4th (pistol match) and 5th (ride planned) don't work for me but other weekends I could shake loose the time.
  6. jmilliken
    Dillsburg, PA
    IWIN.... she's ride-able.... though not registered, tagged, or inspected. Hoping to take care of that one soon. However, not sure if i'd trust her on a hour + ride at this point.... if you wanna make a trip up... check your pm's for more info
    BigT... if you're interested in coming up too, let me know
  7. iwingameover
    the weekend of the 11th just opened up for me. Plans changed. So either of those days I'd make the ride and give you a hand.
  8. schmuckaholic
    California
    (confused look) I didn't think they used YICS in that model year...
    (checks reference material)
    Well, huh. I stand corrected. Carry on, then.
    (You do know that Chacal has all the tools you'll need, right? YICS tools, colortune plugs, the little tool to poke open the holes at the top of the YICS passage...)
  9. jmilliken
    Dillsburg, PA
    Schmuckaholic... at the moment it's a budget thing. Do I buy tools or tires so I can ride again?
  10. zap2504
    zap2504 Member
    Middletown, PA
    Just do one thing at a time. Do the valve clearance checks first. If they all are good (and the valve cover gasket and bolt "donuts" are good) then put the cover back on and construct a manometer (or borrow gauges). Doing the work is not hard nor difficult, just take your time.
