HELP!!! ENGINE CLANKING NOISE!!
Discussion in 'XJ Technical Chat' started by 86maximusXJ700, Nov 7, 2010.
  1. bigfitz52
    It depends on the condition of the cylinders.
    Simply put, cylinders need to be round and straight; if they need boring then you will need oversized pistons and rings.
    If the cylinders are true enough and clean enough that simply honing is all that would be required, AND the piston-to-cylinder clearances are still within spec (based on bore gauge measurements of the cylinders) then the answer is yes IF the pistons are still in good shape. I've done more than one British twin that fell in this category with no bad results. It's simply a matter of measuring; you're either in spec or you're not (excluding actual damage.)
    Your service manual lists bore size, wear limit, cylinder taper limit and cylinder out-of-round limit as well as piston clearances including ring end gap and side clearance limits. The measurements you take in the motor compared to the specs are what answers the question.
  2. Ravenz07
    Ravenz07 Member
    I have always been taught that if your going to tear apart a motor like that, you might as well rebuild it and rebuild it right with no shortcuts.
  3. bigfitz52
    I wasn't advocating shortcuts by any stretch. You only cut metal when necessary, but you DO cut when it's called for.
  4. Ravenz07
    Ravenz07 Member
    I wasnt arguing against you, I am just implying that if he was to take the motor apart to replace the rings, he might as well do a lot more while he has the opportunity.
  5. waldo
    waldo Member
    San Jose, Ca. 95125
    Seems like there is someone missing from all the posts. 86maximusXJ700. I offered to post his pics for him the other day have not heard back from him yet. Leave Bill alone (tears rolling down my face)
  6. schmuckaholic
    California
    http://jamiedubs.com/f***flickr/data/meme-prints/web/leave-britney-alone-02.jpg
  7. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Now that is funny. LOL
  8. BillB
    BillB Active Member
    Tulsa Oklahoma
    If the specs are there, it seems like a ring job would be pretty simple.
  9. 86maximusXJ700
    86maximusXJ700 Member
    Sorry I couldn't get back sooner. Still don't know how to resize pics. cylinder walls are fine. Valve appears to be fine. Only visible damage is top of piston and combustion chamber.
  10. BillB
    BillB Active Member
    Tulsa Oklahoma
  11. 86maximusXJ700
    I ride across town to work everyday and depend on this bike. I would like to take this oppurtunity to rebuild the motor properly, but I'm broke. I'm looking for the cheapest way to get it running reliably. I looked online at the gasket prices and those alone are more than I expected-- $90 for the head gasket.
  12. BillB
    BillB Active Member
    Tulsa Oklahoma
    read back through your post here... we have questions.
    if you had the time you could probably pick up a whole bike for that price but you don't...
    Did you put it back together?
  13. waldo
    waldo Member
    San Jose, Ca. 95125
    I dont think hes online Bill
  14. 86maximusXJ700
    It's still apart. Still can't resize pics
  15. 86maximusXJ700
    Think I finally can post the pics
  16. 86maximusXJ700
    Finally
  17. Ravenz07
    Ravenz07 Member
    Looks pretty nasty. If you really dont want to mess with it, I see XJ motors sell pretty cheap usually.
  18. 86maximusXJ700
    Other than the gouges on the top of the piston and comustion chamber, is there any other damage that I should check for? Could this have affected the lower end?
  19. BillB
    BillB Active Member
    Tulsa Oklahoma
    what is your budget like?
  20. 86maximusXJ700
    budget is exremely limited
  21. 86maximusXJ700
    I'll check back tomorrow. I really appreciate any advice.
  22. waldo
    waldo Member
    San Jose, Ca. 95125
    poor some liquid in the damaged head see if valves leak.
  23. waldo
    waldo Member
    San Jose, Ca. 95125
    did you figure out where screw came from yet
  24. waldo
    waldo Member
    San Jose, Ca. 95125
    any gouges in cylinder wall
  25. TIMEtoRIDE
    That'll buff out.
    Since the head is off, take it to a machine shop and they can vacuum test it in 2 minutes for free.
    The big questions are -
    (From Waldo) "any gouges in cylinder wall ?"
    (from me) did the piston's top land collapse, trapping the ring, causing the ring to no longer work, and imminent failure.
    You would need to remove the piston for inspection.
  26. waldo
    waldo Member
    San Jose, Ca. 95125
    Poor some oil in that too compare it to another cylinder
  27. MN-Maxims
    Saint Paul, MN
    You may be in luck. Depending on where you live and how you could get it. Bluemonster has a XJ700N motor to sell in the for sale forum. He is in Canada. But if you could not get the whole engine from him maybe just the top half would do. Pistons, Cylinders and Head.
    The crown of the piston is damaged and I personaly would replace it. The head you could smoothe out with a die grinder and sandpaper roll. Be carefull not to remove too much material as it would change to cc of that chamber too much. (cc the head is how many cc's of liquid fill the combustion chamber) If you have a machine shop near by you could get an estimate of how much it would cost to check the valves and clean up that chamber.
    Sorry you are on a tight budget but as luck always has it, this kind of stuff never happens when your wallet is full.
    MN
  28. bigfitz52
    It's hard to tell from the pics, is there ANY damage to the cylinder wall or just the top of the piston and the head?
    TIME's questions and advice are spot on; the piston will at the very least require inspection, possibly replacement. How does the top of that piston look, flatness-wise, compared to the others?
    And last but not least, somebody already asked: did you figure out where the screw came from? Do you have it?
  29. TIMEtoRIDE
    Just remembered a machinists' trick - -
    get the piston to the bottom of the bore
    drag a penny around any vertical scratches. If the penny catches, you've got a gouge. You could live with a couple very minor gouges, I guess, but ideally, it should pass this test. You can ignore any flaws in the first 1/4 inch, as they are above the first ring.
    The only way I can think of to check to see if the top ring is "pinched" as I described above,(without removal for inspection), would be to carefully look at it while you rock the piston. But bike tolerances are really tight. You would be comparing the look and feel to the other pistons. If this piston does not rock as much, the ring could be caught.
    So - if you pass the free vacuum test, and the penny test, and the rocking test, you could re-assemble with Indian Head Shellac for $2.00, assuming you didn't destroy the head gasket. (this advise given because you're on a tight budget).
  30. 86maximusXJ700
    :D Good news fellas, I dunno if I'll get in trouble for saying this haha but, I found a full service manual online on one of those file sharing websites. All XJ models and years were there actually. All 222 pages, pictures and all on PDF. This'll help with the rebuild for sure haha. Anyway just wanted to share this little bit of good news. I'll include details on the current damage later when I have time, thanks all.
  31. BillB
    BillB Active Member
    Tulsa Oklahoma
    I hope this works out for you. Let us know what happens.
  32. 86maximusXJ700
    The cylinder wall is undisturbed. When I have more time (probably Friday night) I will check the things that have been advised here. Between work and school it's hard to find the time. My dad let me barrow his '81 virago 750 for the meantime so I got some wheels for the time being. If the gasket is torn in a couple places can i use the varnish and salvage the gasket?
  33. RickCoMatic
    Nope.
    Don't be silly.
    You just dodged a bullet.
    Don't set yourself in the crosshairs again.
    Get a Gasket.
  34. mlew
    mlew Well-Known Member
    Apex, NC
    Think about getting a engine gasket set if you can. While you have the head off, replace the valve guide seals and all the other gaskets. The gaskets aro old and brittle, don't try to reuse them. Thats just asking for oil leaks.
  35. 86maximusXJ700
    any idea how much a complete gasket set will run?
  36. MN-Maxims
    Saint Paul, MN
    Does anyone know if a 82 750 head gasket would work
  37. BillB
    BillB Active Member
    Tulsa Oklahoma
    Nope, two TOTALLY different motors.
    1986 xj700
    1982 xj750
  38. TIMEtoRIDE
    It's my understanding that the 700 was made by reducing the bore of the 750. If that's true, then a 750 head gasket would be a few MM larger (at the piston bore) than needed, leaving a gap that would eventually fill with carbon.
    Other than this, is there a reason it wouldn't work ??
  39. BillB
    BillB Active Member
    Tulsa Oklahoma
    one gasket is for a water cooled bike ???
  40. TIMEtoRIDE
    I don't see the water passage holes . . .
  41. BillB
    BillB Active Member
    Tulsa Oklahoma
    I thought this was a 1986 xj 700.
    When I looked up this year it just shows water cooled bikes. Hmm.
  42. 86maximusXJ700
    No, mine is aircooled, the XJ700XN, commonly called the "Maxim X" is the watercooled version, while mine is just the normal XJ700N.
  43. BillB
    BillB Active Member
    Tulsa Oklahoma
  44. RickCoMatic
    To save some dough for a guy, ...
    I have traced and Cut-out many a Base Gasket.
    Some High Quality Gasket Paper
    Plastic Push Pins
    A piece of Pine Shelf Stock
    X-Acto Kniife
    Sharp Utility Scissors
    Single Hole Punch
    Double-ended Sharpie / Reg and Fine Line
    Drawing Compass
    Finger & Thumb of old Leather Glove.
    Masking Tape
    (Tape the Glove Fingers on so the Razor won't get-cha)
  45. 86maximusXJ700
  46. BillB
    BillB Active Member
    Tulsa Oklahoma
    Is it me or does this one look like its for the watercooled version.
  47. 86maximusXJ700
    Bill was right. Those are water passages. Gasket arrived and although they advertised xj700 it is for a water cooled version. Is it possible to use a sheet of gasket material and make my own head gasket?
  48. 86maximusXJ700
    Ok, we have a problem. So, since the gasket I ordered was the wrong one, I went ahead and salvaged the old gasket and started putting the top end back together. All was going well until I tried putting the cams on, they are binding on the valves. When I turn the crankshaft, I can see that the lobes of the cams are binding against the valves, so the crankshaft abruptly stops. Any ideas as to why this is happening?
  49. MN-Maxims
    Saint Paul, MN
    Sounds like you don't have the cam timing right. Be very carefull you'll bend the valves and you'll be right back to where you started.
    MN
  50. dbikers
    dbikers Member
    grand blanc, mi
    yeah, i would get a new head gasket...imho yer askin' for trouble using the old head gasket....
    just my .02
