Help Help
Discussion in 'XJ Technical Chat' started by e13design, May 10, 2013.
  1. e13design
    e13design Member
    Los Angeles, CA
    I installed the red fork seals from Len. I've done this a few times (once on mine and a few on others). after mounting the tire the forks are leaking oil. everything went smooth, I don't know what went wrong.
    any help on this would be great.
    I'm stuck 3 hours from home.
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    seals upside down? correct oil and air levels? clean surface prior to install?
  3. e13design
    e13design Member
    Los Angeles, CA
    as far as I can tell they are right side up. I polished and cleaned the forks prior to reassembly. I used 230cc of fork oil, as per spec.
  4. e13design
    e13design Member
    Los Angeles, CA
    not what I want to do, but I'm taking it to a shop. I have no choice.
  5. adrian1
    adrian1 Active Member
    Both leaking? Still away from home base? How long before they started leaking? How bad is the leak?
