Help identifying Mikuni Carbs
Discussion in 'Other Motorcycles' started by Paul Howells, Jan 18, 2020.
Tags:
  1. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    Hello All,
    I found these carbs in a box buried in the back of my sister-in-laws shed. They are stamped Mikuni and Made in Japan but I don't see any other markings. Does anybody recognize them and know what machine they are from? I am assuming they are from a UJM but I guess they could be off a car or snowmobile.
    IMG_20200118_123955.jpg IMG_20200118_123921.jpg IMG_20200118_123910.jpg IMG_20200118_123900.jpg
    Paul
    hats and bowls with enrichment circuit on side look like suzuki carbs.
    i hope the letters jb on the bowls does not meen JB weld posts
    Timbox likes this.
  3. Paul Howells
    Victoria, BC
    @XJ550H I will take off the float bowls and look for the JB weld.
    I saw some similar carbs on eBay for a GS1100 but there are some differences so I haven't nailed down an exact match yet.
    Toomanybikes likes this.
  4. XJ550H
    there looks like there is a rod on side of carbs with thr rubber boots.
    looks like the hose is hooked to overflow
    tee between carb 2 and 3 is fuel supply
    looking at carbs on partzilla from 1980 up may help
  5. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    I'm suspicious of them being 1979 or older. Yamaha Mikunis had steel tops beginning with 1980. Search Suzuki GS carburetors.
  6. Timbox
    I don't see how the throttle attaches to them? Is it from the side or over the top like most motorcycles. The bowls have the drain screws like so many of the before 1980's bikes had. Double fuel line inputs they have set up as a "T". My XS1100 is that way. If you do a little more cleaning you might be able to see a mark on them. This link might help you too, they sell all kinds of replacement rubber for carbs. http://jbmindustries.com/
  7. XJ550H
    from a suzuki rebuild tutorial
    Starting in 1980 (in the US market anyway) all
    GS bikes adopted Mikuni BS (CV) carburetors.
    • These carburetors came in three sizes
    (denotation reflects the inside throat diameter by
    the butterfly throttle valve):
    – BS32 (32mm) for GS550, 650, 750, 850
    – BS34 (34 mm) for GS1000 & 1100 – also 450
    (although the 450 configuration is somewhat
    different)
    – BS36 (36 mm) for the GS1150
    the carbs had 2 styles of hat
    black and silver carbs are from GS 1150
    Timbox likes this.
