HELP! Is having a rev limiter necessary? Digital speedometer install.
Discussion in 'XJ Modifications' started by Shabby cube, Jan 6, 2021.
  1. Polock
    i had one like that, it came out like this.
    get a piece of brass rod about 1/4 inch and 1.5 inches long
    strip the carb of anything that will burn/melt
    chunk of plumbers solder with lead, also 1/4 inch long
    solder flux down the hole then the solder then the brass rod
    now HEAT THE CARB AREA till the solder melts, then a little more heat on the brass rod just to be sure
    hold the rod centered till it's solid and unscrew it, mine was still very tight
    i was surprised it worked but the next step was the garbage can, i reused that screw
    Shabby cube and k-moe like this.
    One more thing. It might take more than one heat cycle for it to break loose. Be patient.
    Shabby cube likes this.
  3. Shabby cube
    Shabby cube Member
    Norway
    How does that work? I would expect the solder to break loose from the screw, solder is usually not that strong in my experience... by solder flux you mean the stuff that looks like some fat gel right? ...feel like I would be way over my head with that technique...
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Ooo, now that's a new one - might try that one day. See no reason it shouldn't work.
  5. Minimutly
    West Wales, uk
    If you can melt alumina with a butane torch hats off to you!
  6. k-moe
    You're right about the butane. I use my propane torch in the kitchen, because I'm too cheap to own more than one torch...lol.
  7. Polock
    don't know how much torque that solder joint could take but once the head is stripped out you can't put any torque on it
    i'm no welder but could you stick a welding rod to a steel screw ?
  8. hogfiddles
    Not on mine......I’ve gone over redline a few times. Those who have been to CNYCC’s have seen it a few times
    TheCrazyGnat and k-moe like this.
  9. Minimutly
    West Wales, uk
    Mixture screws are brass.
  10. k-moe
    Not always, but the OP's sure are.
  11. Shabby cube
    Shabby cube Member
    Norway
    VICTORY!!!!!!
    (Penetrating oil for 2 days, didn’t need to apply heat, nerve wrecking dremel tool job....)
    Franz and k-moe like this.
  12. k-moe
    Once you get the carbs working properly and dial the idle mixture in, you should think about making a rubber cap (from the rubber "clay stuff" arts supply stores carry, Sculpey is one brand) to help protect the slot in the new mixture screw.
  13. Polock
    except the ones that are steel
    Minimutly and k-moe like this.
  14. Polock
    that sounds like a job for a 3d printer ;)
  15. Shabby cube
    Shabby cube Member
    Norway
    Yes! Definitely don’t want to have the same problem in future.
  16. k-moe
    Maybe if I ever make time to learn how to do the CAD part. Summer is coming though, and I do have the desire.
  17. Minimutly
    West Wales, uk
    You live and learn - never seen one myself.
  18. Shabby cube
    Shabby cube Member
    Norway
    93AE4F1B-B680-454E-8E0B-A7DE4BCCE48E.jpeg E483CFFD-107B-4F53-B4E1-6E822F0AAE8B.jpeg Adjusted mix screws until I got the highest rpm with the least amount of weirdness ( revs up and down fast and doesn’t sputter, no backfires in exhaust).
    I did a carb sync and the bike sounds absolutely amazing!!!
    None of the old strange engine sounds, PLUS, all the headers get hot now! Firing on all cylinders!!!
    TOOLS:
    - 2 inch t-shirt strip with a few knots (one knot per 2-3 inches) drenched in 2-stroke oil to block the YICS port.
    -tubes of equal length filled with 2 -stroke oil as a make-shift carb sync tool. Videos of similar stuff on YouTube.. ( using that is a bitch and a half, had to wait for the oils to set between each adjustment.. or just try to make them all stop moving where they are by adjusting carbs. Took about an hour just doing those adjustments...)
  19. k-moe
    Next time you can skip blocking off the YICS ports. Use smaller diameter tubing inside each of the tubes going from the engine to the manometer so the pulses are dampened. Makes reading the oil levels easier.
  20. Shabby cube
    Shabby cube Member
    Norway
    People on here say blocking the YICS is super important, so they got to me. I know it's a debate long as life itsself :p Smaller tubing, great idea.
    NOW.... I got more issues... a little bit of oil sweating from the upper part of my engine... I tried to block it with some metal filler, but it still sweats through when I run the bike... WHAT TO DO?
  21. Minimutly
    West Wales, uk
    Metal filler is going to struggle there - what happens is that the pressure builds up behind it, and there is nothing stopping it lifting away.
    I would drill and tap the plug, pull it and make a new one - maybe you have a machine shop locally that can make you one?
    Tried chacal?
  22. Franz
    Would a helicoil work?
  23. Shabby cube
    Shabby cube Member
    Norway
    The thing is.. there was some brown "stuff" there before, and it looked really stupid.. So I removed it, since oil has been seeping out there. So it is possible, it WAS blocked..
    What I'm cusious about is what the f*** that "port" is, why is it there? and why is it leaking?
  24. k-moe
    Not in that application. Tapping the bore for a threaded plug (as the factory did in about 1/2 of the heads) will make for an oiltight seal, or a new plug can be pressed in.
    Franz and Shabby cube like this.
  25. k-moe
    That is where the oil gallery for the exhaust cam was drilled during production of the head. The plug was either a press fit, or a threaded bolt with sealant. Both were used by the factory to seal the oil gallery.
    You have another set of plugs on the intake cam oil gallery.
  26. Shabby cube
    Shabby cube Member
    Norway
    This sucks tho, isn't drilling into that thing gonna put metal shavings inside the oil gallery then? Anybody know how deep that thing goes?
  27. Franz
    It must go all the way under the camshafts to feed oil to the cam journals. Misunderstood you mean the depth of the plug or threaded bolt.
  28. k-moe
    1. YOU won't be doing the drilling, a machine shop will.
    2. The drilling to remove the plug will not go all the way through the plug, it will be removed with a puller after there is a hole and threads made in the plug for the puller to grab. (this is the ideal method, but it dosen't always work. The alternative methods do produce chips that can potentially get into the oil gallery, but that is dealt with later).
    If a threaded plug is used instead of a pressed-in plug the hole will be threaded with grease on the tap that will catch all of the chips. The oil gallery will then be flushed out from the inside of the passages (oil/ solvent/ metal cutting coolant (depending on the shop) will come out of the open end of the oil gallery, washing any remaining debris out with it).
    3. It runs all the way out the other side of the head. You'll find another plug on the opposite side of the engine.
    4. While not a common failure, it is one that machine shops around the word get to do on all sorts of machinery several times per year.
  29. Shabby cube
    Shabby cube Member
    Norway
    Thanks you K-moe! How expensive are machinists tho? I agree it’s scary to drill there and letting a professional do it would be best.. peace of mind and that
  30. Minimutly
    West Wales, uk
    It's one of those jobs not hard to do, but easy to cock up. Drilling all the way through the plug would be classed as cockup No1. Don't be under the impression that any bike shop could do this job, it needs some (simple) but careful engineering.
  31. k-moe
    That will vary. I was quoted $100 for a more difficult, but similar job to repair a messed up threaded hole and rebuild the part of it that was missing. Your job should not be more than that, and might be less. A replacement (used) head will cost more, and that's without shipping.
    Call around and get quotes. Have the pic ready to email, and let them know that you have it.
  32. Simmy
    Those metal epoxies will make a quick and painless repair. What have you got to lose?
    I patched a broken water pump housing on the kids dirt bike, even had a chunk missing. Rode for a year then sold it with the repair still holding.
  33. Shabby cube
    Shabby cube Member
    Norway
    Like JB weld? I mean why not try right? Im suspecting it won’t work because of oil pressure, but wouldn’t cost me much to try..
  34. Shabby cube
    Shabby cube Member
    Norway
    890AE6A0-3F1E-4BA0-A437-DBC2AB4BD66E.jpeg 244D8FD8-3FED-49FA-9C97-3115E9488536.jpeg Sorry for the delay, COVID got me depressed and out of money there for a while, but I’m back at it! Rode the bike with a leak for a while and had a really good time!
    I went to a local cylinder service shop and paid 1300 nok (130 £ ish ) to block the oil leak! Pretty okey price, did it in one day.
    The bike is now gangster with a gold tooth yo!
    ( great to be able to lean into a corner without having oil dripping onto the rear wheel hehe)
  35. Shabby cube
    Shabby cube Member
    Norway
    MORE ISSUES THO!
    Like I said, I’ve been riding a bit, smaller trips. But issues occurred when I tried taking the bike in the highway.... engine started bogging down and eventually stopped. This happened a few times. First time I assumed it was out of fuel. The tank was low, but not empty. But I filled up and it started up again. Hmm curious. But it kept happening. It would bog out, I would then spend some time checking fuel lines, chokes system, air filters, battery... and then it would magically start again...
    I started thinking it was a too large main jet, maybe high rpms was drowning the engine?
    then I did some research and realized: this is the excavator symptoms of engine overheating .... I had filled too much oil when I did the oil change last year.... didn’t think it was that big of a problem right... hehehe. So, too a sample of the oil, to check the state of it: 820D389A-A550-4822-A7F7-059D46A31FE3.jpeg bubbles...... oil looks like whipped cream ...
    Long story short, gonna do oil and oil filter change CORRECTLY... and pray to the MC gods that I haven’t done too much damage to the engine.
    pray with me guys
  36. Shabby cube
    Shabby cube Member
    Norway
    Changing the oil and oil filter didnt help, still bogs out under acceleration and get difficult to start.
  37. Shabby cube
    Shabby cube Member
    Norway
    Turns out a clogged fuel filter can cause lean condition/overheating/bogging out. Replaced fuel filter with washable version. Rode bike all day without issues
    chacal and Franz like this.
  38. Shabby cube
    Shabby cube Member
    Norway
    … Rode bike a full season! Very happy with it! This winter I am replacing the strange xj handlebars with some MX bars.
    ISSUE: I needed to stretch the cables from the handlebar. I bought a cable repair kit and some outer wire housing for bicycles and clutch wire at 1.5mm thickness. It operates fine now that I fitted it on the bike, but I can’t help but worry that the MUCH thinner clutch cable I fitted on will crumble under the force of the clutch… Is “clutch wire thickness” important? Or can I relax as long as it operates well for now?
    (Good place to buy thick clutch cables anyone?) E2EC821B-21E6-42E1-8D1A-D0C72787F993.jpeg 31539DDC-DC20-4B4E-85AC-BE2B770BF925.jpeg 748BFF6F-E0BC-4D4C-B11F-8443ECCD630A.jpeg
