Help me
Discussion in 'XJ Technical Chat' started by Kenneth mutzabaugh, Aug 24, 2017.
Tags:
  1. Kenneth mutzabaugh
    Kenneth mutzabaugh New Member
    Duncannon, Pa
    Ok so i just bought a 1982 seca 650.
    Now im not getting nothing when i press the start button, but the instrument cluster lights up. Now i did manually crank the bike from the starter. But any ideas on why the electric ignition wont work? Not even a click.
  2. Polock
    some bikes need a good connection from the switch housing to the bars, some have a ground wire. twist the housing a few times, see if that helps
    Kenneth mutzabaugh likes this.
  3. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Starter buttons on these bikes are notoriously crappy and fail often.
  4. Polock
    just the other day, i opened the housing and squirted it out with brake cleaner. it's been funky for years, works good now
  5. taptapindustries
    taptapindustries Member
    maroubra
    yep i had same dodgy start button on the xj650. Opened it up tickled the contacts with a screwdriver, cleaned it best i could with out getting too carried away and squirted it with a bit of wd40. put back together and is been fine for the last 8 odd years since...
