Help! Need advice on what I should look into to fix new old XJ750 Maxim.
Discussion in 'XJ Technical Chat' started by Elter, Sep 6, 2024.
  1. Elter
    Elter New Member
    AB, Canada
    Hey guys I just picked up a 1982 XJ750 Maxim for $80 CAD as my first bike (technically didn't even cost me that much since I traded it for some work I did for a guy), but it hasn't been registered since 2004 and I don't even know the last time it ran, it apparently would run for about 5 mins and then die when it did run, it's been sitting outside for quite a long time as well.
    I'm just wondering what I should look into repair/parts-wise to get it going again, it has leaky fork seals, and I can't move either the front or rear brakes at all, but I have no clue about bikes or what I should look into to get it running so any advice would be greatly appreciated.
    Here's the bike.
  2. Dan Gardner
    Minneapolis, MN
    Hi @Elter - welcome to the party!
    That bike looks pretty nice and complete to me (relatively speaking). I don't see any reason why it would not be able to live a good life again.
    If it were me, I would want to hear it run first. For better or worse, that means bringing the carbs back to a good running condition, which is often the most difficult part.
    How would you rate your wrenching skills in general??
  3. Elter
    Elter New Member
    AB, Canada
    Thanks Dan, I consider myself fairly competent, I've never been afraid to tear stuff apart on my (or anyone else's) truck but I've never worked on bikes before and from the thread I was reading on here about rebuilding the carbs it seems like a pretty decent sized undertaking, is there anything else I should look at to get it started that might have died from sitting (other than the battery, gas and oil)?
    The bikes odometer says 58,000 km and I heard the guy who owned it wasn't much of a mechanic.
  4. Dan Gardner
    Minneapolis, MN
    Of course you can always take the carbs off, shoot some starter fluid straight into the carb boots and see if it will run for a second or two. Its a little bit of a violent adventure, but that would tell you if the ignition is working, the engine has compression, etc.
    The carb overhaul is a decent sized undertaking. However, there is plenty of information here to pull it off. I think the key is that you need to have meticulous attention to detail to make sure everything is clean - i.e. "The Church of Clean". These devices aren't that complicated, three circuits, but there are very small passages that all need to be free flowing to work correctly. Auto application carbs have enormous passages compared to these carbs.
  5. Elter
    Elter New Member
    AB, Canada
    Ok, might try and give that a shot, where would be the best place to find parts to (very carefully) rebuild the carbs? I figure they're probably pretty plugged up from 15-20 year old gas.
  6. Dan Gardner
    Minneapolis, MN
    @chacal from xj4ever is the best place to get parts. See the link in the upper right of this page.
  7. Rooster53
    making sure the motor is not frozen would be a good place to start before spending any money on it
    chacal likes this.
  8. Elter
    Elter New Member
    AB, Canada
    Well good news, I stuck it in a high gear and was able to roll the engine over from the wheel so at least I know it's not seized up.
    Can I put a car battery on it for temporary testing until I can pick up a new battery?
    Rooster53 and Dan Gardner like this.
  9. Elter
    Elter New Member
    AB, Canada
  10. Dan Gardner
    Minneapolis, MN
    Yes.
  11. Dan Gardner
    Minneapolis, MN
    That’s some real nice work. You will probably need to put that on the list of stuff to fix someday.
  12. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    It's a beauty! I started with an '82 750 also and have been on a short and steep learning curve about these bikes ever since. The 3 biggest struggles I had (still have!??) as a newbie...carbs as already mentioned. They are mysterious and complicated, then all of a sudden make sense. Wiring - on a bike that has sat, you'll have corrosion in lots of terminals to clean. Get a wiring diagram, and learn the ignition circuit and the various relays involved and how to test them. Valve adjustment - first time is overwhelming, but after a few its old hat.
    I think the '82 750 Maxim is one of the ugliest XJ's, but they've really grown on me. Oh, get a manual. The Haynes one is pretty good. Good luck!
    minimuttly likes this.
  13. Elter
    Elter New Member
    AB, Canada
    Lol I suspect the issue I'm gonna have most of all is cash flow to buy parts.
  14. Roast644
    WASHINGTON
    No need to dump lots of money into it til you know what you have. The carbs are a fine place to start, and the cost might only be float needles and gaskets. You can get new, cheap carb boots between the airbox and carbs on ebay and they are actually well worth the cost for the hassle they save installing the carbs.
    While you are reading up on carb cleaning, you could check compression to make sure you don't have any major issues, and check spark, but I bet since it was sitting outside all that time you will be fighting lots of corrosion. Again, that isn't necessarily new parts, just lots of labor.
    Here's a link to the carb info. If you don't like to read that much, search for posts on carb cleaning with photos, ask questions, you'll get it.
    https://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
  15. Elter
    Elter New Member
    AB, Canada
    I figure getting it running shouldn't be too bad, but once it is running I'm gonna have to replace almost everything brakes-wise (which is gonna be the pricey part) and it's definitely gonna need new tires
  16. Elter
    Elter New Member
    AB, Canada
    Can I save a bit of money with an eBay gasket kit or should I just pay the little bit more and buy from Len to be on the safe side?
  17. Elter
    Elter New Member
    AB, Canada
    More good news, didn't even take the carb off I managed to get it running off a car battery, and some starter fluid sprayed into the carbs, it seemed to continue running after that (at least until the probably undersized fuse blew) but is burning pretty blue, but I'll have to see what that does after an oil change
