Help, new member !
Discussion in 'XJ Technical Chat' started by Shortmedic, Jul 14, 2019.
Tags:
  1. Shortmedic
    Shortmedic New Member
    Springfield,MO
    Hey guys , I recently got ahold of a xj1100. It's a bit of a peice of work right now but I like a challenge. It's a junkyard bike but the engine looks solid. I looked at the shorty vin to 17 vin thread and I'm at a loss (I'm terrible at maths).Can any yall help me with the shorty to long vin ? Its 10M-003696 ? Any help is greatly appreciated, I'm so glad the place exists !
    JYA 10m00 2 CA003696
    10M-003696
    1st position:1 x8 = 8
    2nd position:8 x7 = 56
    3rd position: 1x6 = 6
    4th position:1 x5 = 5
    5th position:0 x4 = 0
    6th position:4 x3 =12
    7th position:0 x2 = 0
    8th position: 0x10 = 0
    9th position: unknown, this is what you're trying to figure out!
    10th position:3 x9 =27
    11th position:1 x8 = 8
    12th position: 0x7 =0
    13th position:0 x6 =0
    14th position:3 x5 =15
    15th position: 6x4 =24
    16th position:9 x3 =27
    17th position:6 x2 =12
    total =200
    200/11 =18.18 18*11=198 remainder 2 = chec digit
  3. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I'll bet my house that bike never get's on the road.
  4. Shortmedic
    Springfield,MO
    Thanks for the help ! XJ550H ! Stahlmaster, I wouldnt take those odds I'd likely lose. It's more or less a tinker project for the back half of my shop. Your right itll probably never see the road again, but hey I'll learn alot on the way ! Blessings mate!
  5. XJ550H
    it will keep you busy
  6. Shortmedic
    Springfield,MO
    It's kinda what I was hoping ! I need a project again!
  7. firebane
    firebane Active Member
    Calgary, AB
    Problem with these.. is that even though it was "free" or "cheap" .. they end up being the most expensive bikes.
    Franz likes this.
  8. Shortmedic
    Springfield,MO
    Well I'll see how far I get Haha
  9. XJ550H
    unless motor is damaged 1500 will have a mighty nice bike under your seat. that would cover tires wheel bearings brake system rebuild,fork seals and hardware carbs rebuilt petcocks shims seat cover and padding and a few odds and ends. even at 2 grand you will have quite a ride and can work on shinny stuff as you ride it
    go crazy on paint and the skys the limit
  10. Shortmedic
    Springfield,MO
    Thanks for the advice Xj550h!
  11. Timbox
    At least it has the air box with it! In the pic is that all that came with the bike? I have a XS1100 I am still working out the kinks on, so I will be watching you work on yours. One of the things you might need to check is the wires on the left side for the timing pickup. The blue wire on mine was broke (common) and needed to be soldered. The nice thing with these bikes is the carbs area okay to pull and put back in.
    Keep us posted with progress and when needed step away from her for a bit if it gets overwhelming.
  12. Shortmedic
    Springfield,MO
    Yep! when I picked her up she was grown into the weeds ! She looks relatively together! Unfortunately I've noticed today she is fork locked. Any idea on how to fix that. The key is no longer with it.
  13. sybe
    sybe Active Member
    NYC - Brooklyn
    Disconnect the old ignition switch [key part] and buy a new one. The ignition switch has a post that sticks out when you turn the key to lock the forks.
  14. sybe
    sybe Active Member
    NYC - Brooklyn
    I am not one to tell others what to do, but that bike might not be worth the time and energy. I would focus on the engine first; compression, leak down, shims etc.... If everything looks good with the powerplant then move to the carbs. there is a reason the bike was at the junk yard. you dont want to find out 75% into the build that its a middle gear or bearing are shot in the motor.
    Simmy and Chitwood like this.
  15. XJ550H
    ignition is held in place with 2 bolts 10 mm and a long extension and it is off. also the key number may still be visable on bottom of lock order a key off of ebay there are 2 vendors 1 sells 1 cut key 10$ the other sells 2 cut keys 20$.
    my 550 had trees growing up through the wheels and one going up between rear fender and motor
    Clean and lube the ignition switch
    Your Gas Cap and You
