Help - Rear wheel removal - exhaust blocking axle
Discussion in 'XJ Technical Chat' started by ColoradoDan, May 23, 2026.
  1. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    Hey XJers, I am scratching my head on this, and need some help if someone knows.
    I have an 82 XJ650, with stock exhaust. I've changed my rear tire several times over the years, and always need an extra step to get the axle around the right side exhaust, but for the life of me can't remember the trick I've used.
    I know I've never removed the exhaust itself. And I can't remember needing to disconnect the shocks, but maybe that was the method.
  2. Dan Gardner
    Minneapolis, MN
    Seems like something must have shifted ????
  3. ColoradoDan
    Longmont, CO
    Maybe from before i bought it?
    Everything is locked in as much as stock would be. The pipe bracket is still mounted to the rear peg bracket. Essentially it looks like any stock photo.
  4. Dan Gardner
    Minneapolis, MN
    Maxim or Seca?
  5. ColoradoDan
    Longmont, CO
    Maxim. But I ended up removing the rear peg bracket, and that let me move the exhaust upwards enough for the axle to just barely slide under it. Must be what I did last time, so I plan to write it down this time lol
  6. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    That's sorta odd. On my 1980 XJ650 Maxim, the muffs ended just far enough in front of the axle to not get in the way of removal:
    Did the '82 have longer mufflers? Is there that much variation between bikes? I mean, it's a shaft drive so the axle doesn't get adjusted forward and back! Odd...
  7. Dan Gardner
    Minneapolis, MN
    My 82 looks just like your 1980. No interference with the axle and exhaust.
