Help. Setting fuel level on my carb... Drain screw stuck
Discussion in 'XJ Technical Chat' started by Victor Hugo, Nov 3, 2020.
  1. Victor Hugo
    Victor Hugo New Member
    Mexico
    Hi guys, I need some help with my maxim, I'm trying to adjust the fuel level in the mikuni bs33 carbs for the xj700x, but when I tried to open the drain screw it looks like it's stuck, I used wd40 but it doesn't seems to work, the carb was sitting for years, any ideas?
    If I can't get the drain screw open, I'm going to set the height float height as in the manual, 17,5mm +/-1mm, but I would like to check the fuel level.
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    A wet set is needed, not a bench set. WD-40 is not a penetrating oil. Try Liquid Wrench or PB Blaster instead.
  3. Victor Hugo
    Mexico
    I used this too, It is pentrating oil but it doesn't work
    Remove the float bowl. Dry it good. Use some heat on the float bowl (200ºF is plenty) and then a handheld impact driver on the screw.
    StahlMaster likes this.
  5. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    In the past I've heated the screw with a 100W soldering iron, then cool it quickly (pot of ice water) It helps break the bond.
  6. XJ550H
    soak it , soak it some more and keep doing that from inside and out side of the screw.
  7. Victor Hugo
    Mexico
    sorry for my ignorance, how could I heat the bowl?
    do I soak it in carb cleaner?
  8. Jetfixer
  9. XJ550H
    soak with penatrating oil on the head of the drain screw and in the holes in bottom of bowl you could drop it into a jar of acetone and automatic transmission fluid 50/50 mix.
    tou want to heat the screw with a torch it will expand the screw .
  10. Toomanybikes
    Tsawwassen bc
    If all your efforts fail I do have a set of Mikuni carbs that are in parts.
  11. Victor Hugo
    Mexico
    I soaked it, it's still soaking, in the night I'll try to open it, I hope it works. I used the same oil "aflojatodo" I have used before, if it didn't work I will use the mix of acetone and trasmision oil. So the heat is a bad idea?
    Do you ship to Mexico?
  12. XJ550H
    heat will work
  13. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    screw the float bowl down onto a piece of wood , put the wood in a vice to use the impact driver
    a100man likes this.
  14. Toomanybikes
    Tsawwassen bc
    FF04F637-0F6F-4129-B2BC-D2C3B55209B6.jpeg Don’t be afraid to pour the coal to it. A good quality screwdriver and applying torque to it and heat until she pops loose. Have only lost the battle once in the last 5 years
    Franz and k-moe like this.
  15. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I replaced my bowl drain screws with hex screws from xj4ever. Haven't had a single regret or problem since.
  16. joejr2
    Santa Fe,NM
    I had that happen a few times and what I did was to first soak the screw in penetrating oil,
    then heated it with a dry heat gun, lastly I froze it by squirting it with the propellant from
    A can of compressed computer blaster air turned upside down. After alternating hot and
    cold A few times,I was able to back it out with a cordless impact screw gun. I have used this
    on a lot of stuck bolts
  17. k-moe
    Many methods. Most involve taking advantage of the different expansion rates of the different metals, and bit of carefully applied force.
    Worst case (and there is a worst case), you center punch the screw and slowly drill out the center with increasingly larger drills until you hit the minor diameter of the threads, and then use a dental pick to peel out the remainder. I haven't had to resort to that with a float bowl drain screw yet, but it's worth knowing about.
  18. Polock
    take the bowl off and screw it to a piece of wood now it's solid and won't twist or move, now do all the other things suggested
  19. Victor Hugo
    Mexico
    Thanks everyone, I was finally able to get the screw out.
    If someone has the same problem, what worked for me was to heat it up with a torch for two minutes, I did it as in Toomanybikes' image, after that it was like magic, the screw came out easily, the torch costs about $ 10 dollars.
    I also found this video, it may help someone else with the same problem.
    Rooster53 and XJ550H like this.
