Help! Stator replacement.
Discussion in 'XJ Technical Chat' started by beardedwonder, Jul 17, 2016.
  1. Jetfixer
    Then if it jumps up after start , chances are your stator is ok . Agree with hogfiddles sounds like you have an ignition problem TCI or coils...look at coils see if they are cracked , if bad enough with lights out you might see some arcs ( Replaced my coils with 82 Honda CB 750 coils --replaceable plug wires big plus). Test TCI is another thing, usually swap in a new or used unit is quickest way.
    beardedwonder and DrewUth like this.
  2. DrewUth
    DrewUth Active Member
    South Jersey
    Run the bike until it shuts off, then pull the plugs and check for spark before it "cools down"
    k-moe, beardedwonder and Big swede like this.
  3. k-moe
    ^ That. Pull one plug at at a time though, or you will risk damaging the TCI.
    And check valve clearances.
    Not every problem has a single cause.
    DrewUth, beardedwonder and Jetfixer like this.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    My wife wholeheartedly disagrees :D
    Lightcs1776 and Stumplifter like this.
  5. hogfiddles
    Well, that's a whole 'NOTHER problem....
    Lightcs1776 likes this.
