Help with headlight
Discussion in 'XJ Technical Chat' started by Ian Green, Feb 22, 2021.
  1. Ian Green
    Ian Green Member
    Antrim
    Hi all i have been givin a 1991 XJ 600 real scruffy but all was working apart from the tail lightstraced it to a broken wire fixed it and now they work problem is the headlight has stoped working checked for contnuity and everything seem fine even tried a new bulb. Is there anything i could try any help would be very much appreciated
    Start by checking your fuses. You may still have a bit of bare wire touching the frame somewhere.
    Ian Green likes this.
  3. Ian Green
    Ian Green Member
    Antrim
    All fuses are good. I did buy a haynes manual just for the wiring diagram but the diagram is usless as there is no legend or colour codes for the wires so i have no idea what colour traces go to where
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If the 600 is like the 550 the headlight comes on when the engine is running.
  5. XJ550H
    Antrim NH ?
    I ask because you spelled color, colour.
  6. Ian Green
    Ian Green Member
    Antrim
    Antrim Northern Ireland the headlight comes on without the engine running
  7. k-moe
    A color diagram can be found here. Edit: wrong model and year. Give me a minute and I'lll find the right one.
    viewtopic.php (SecaII diagram if anyone needs it).
    Edit #2
    A free with account copy: XJ600 Wiring Diagram
    I'll keep looking. I thought I had a PDF of it saved but can't seem to find the thing.
    It's unlike Haynes to not have each wire labled with color codes, but every publisher does make mistakes occasionally.
    Also check that the headlight switch is functioning. The contacts might need to be cleaned.
  8. XJ550H
    check for voltage at headlight socket black is ground
    green wire is low beam
    yellow wire is high beam
    from key it is a blue with black stripe to high low switch
  9. Ian Green
    Ian Green Member
    Antrim
    Colour diagram is great thanks for that i have already cleaned the switch gear
  10. XJ550H
  11. Ian Green
    Ian Green Member
    Antrim
    Is black wire a common ground?
  12. XJ550H
    I have a 1992 xj600 factory service manual in pdf if that will help you I can upload it to we transfer
  13. XJ550H
    yes black is common ground
    you have a main switch (1) and a lights switch (32) ?
  14. Ian Green
    Ian Green Member
    Antrim
    Factory service manual would be great Thanks XJ5550H
  15. XJ550H
    link in your inbox good for 7 days
  16. k-moe
    Note my edit. I linked the wrong diagram before.
  17. Ian Green
    Ian Green Member
    Antrim
    Thank you so much everybody i shall let you know how i get on
  18. Ian Green
    Ian Green Member
    Antrim
    Hi again how do i check for voltage at headlight and if there is none where do i go from there
  19. Ian Green
    Ian Green Member
    Antrim
  20. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    haynes wiring diagram for the xj600 is shyte, the key numbers dont match, and theres no colour key,
    if you now have the correct diagram ,
    if you dont have main or dip lights working then chances are , the fault is earlier on in the circuit,.
    first check for voltage in and out of the fuse with red/yellow wires
    if you have a multimeter, set it to dc volts 20ish, put one probe on a good earth ,or battery earth
    put the other probe on the fuse, both in and out with ignition on
    red /yellow wire then goes to the r.h. light switch
    check for voltage there in the same way
    wire colour then changes to blue / black, check for voltage there on the blue/black
    the blue / black wire then goes to the high / low beam switch on the r.h
    let us know how you go on up to there
    if you dont have a multimeter a test bulb with 2 wires attached is just as good
    i prefer a test screwdriver with earth wire , for initial testing
    stu
  21. bensalf
    yorkshire ,england
    by the way , 1991 xj600?
    we are talking a 3km, pre diversion, model here aren't we and not the 4br diversion model, i think that was available that year
  22. Ian Green
    Ian Green Member
    Antrim
    Yep pre diversion just done what you said checked r/y wire at the fuse box all ok 11. something volts moved up the loom to where right hand switch gear joins the loom connected to the r/y wire loom side of the block and there was a sound like a spark and know i have nothing checked all fuses all ok replaced them just for good measure and nothing it is completley dead
  23. bensalf
    yorkshire ,england
    start again at red /yellow wire on fuses, in and out
  24. Ian Green
    Ian Green Member
    Antrim
    Nothing at the fuse box now
  25. bensalf
    yorkshire ,england
    anything on the red wired fuse?
  26. Ian Green
    Ian Green Member
    Antrim
    12.56v from red wire in and out
  27. bensalf
    yorkshire ,england
    red wire goes to ignition switch, then colour changes to brown , then goes back to the fuse box brown wired fuse, test the brown wired fuse ,in and out, that then splits to the red / yellow fuse , and the red / white wire fuse.
  28. Ian Green
    Ian Green Member
    Antrim
    Thanks i shall let you know how I get on tomorrow as it is getting late here
  29. Ian Green
    Ian Green Member
    Antrim
    Hi all found the promlem broken red wire from the ignition switch which was connecting and then not so Thank you all for the help. Now next step is fork seals and brake rebuild with braided lines
