Help! XJ700 Starter issues?
Discussion in 'XJ Technical Chat' started by prulla, May 28, 2024.
  1. prulla
    prulla New Member
    Tempe
    I’m attaching a video of the sound my bike makes when i go press the start button (if i can figure it out). It clicks and makes a whirring noise and all the lights shut off when the start button is in. Does anybody recognize what this might be? I bought the bike non-running it’s an 85 XJ700 Maxim.
  2. Dan Gardner
    Minneapolis, MN
    Without seeing the video- what is the battery condition??
  3. prulla
    prulla New Member
    Tempe
    Brand new battery. I also just took out the starter and tested it hooked up straight to the battery and it spun fine
  4. prulla
    prulla New Member
    Tempe
  5. Jetfixer
    You might remove the starter look in , you might have stripped the gear that engages the starter clutch, afraid only way to fix it is to pull engine and split the case . The starter clutch has three pawls rollers and springs if these stick or worse the clutch is cracked it will not engage.
