Help.
Discussion in 'XJ Technical Chat' started by 1%Doc619, Sep 21, 2017.
  1. 1%Doc619
    1%Doc619 New Member
    San Diego
    hello, so my 82 xj750 seca, I changed out the fork seals, and for some reason the brakes won't work now. I heard the brakes run off the same oil as the forks. I would like to know how to get my brakes working again. I tried bleeding the brakes but no luck. Any help would be appreciated.
  2. Dadoseven
    Dadoseven Active Member
    Omaha
    The brakes do NOT run off the same oil as the forks. The 750 Secas do have anti-dive units which are controlled by the brake system. They indirectly affect the flow of oil in the forks to slightly stiffen them during braking. Did you bleed at both the caliper and the anti-dive units?
    Not sure why redoing your forks would affect the brakes, unless the hydraulic system was inadvertently opened up.
    How old are your brake lines?
  3. XJ550H
    bleeding dual disc can be a real pain there are a few threads on it here
    Brake fluid change
  4. Jetfixer
    You need DOT 3 brake fluid....DO NOT put anything else in system.
