Help
Discussion in 'XJ Technical Chat' started by Deathboner727, May 18, 2018.
  1. Deathboner727
    Deathboner727 New Member
    Ohio
    I have a 82xj750 j maxim did compression test numbers yesterday 115 ish on all cylinders. Saw on the forums 128 was considered low. My question is how necessary is a ring job or other things to look at? Top end was rebuilt over winter new valve shims and seal. Therese no oil leaks or smoke out of exhaust. Any input would be appreciated-cheers-
  2. fastenova
    fastenova Member Premium Member
    Redmond, OR
    How does it run? If compression is even across all four cylinders, then you can still tune and ride it. Just have to decide if the fuel economy, possible oil consumption, performance is acceptable to you, and if so, then keep riding it. I had similar compression numbers on my bike except two were lower than the others. This made it difficult to tune properly, no matter how much time I spent on the carbs, and I was getting approx 25MPG so I decided to overhaul the top end (oversize pistons and rings, full valve job).
    I am expecting to see a marked improvement in performance after the break-in period, and hope to see MPGs in the mid-40s.
    Deathboner727 likes this.
  3. Deathboner727
    Ohio
    She runs strong. I’ve been working on dialing in carbs this season. Synced carbs and colortuned. My plans were to just ride and consider new rings this winter. I’ll keep an eye on the oil consumption
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Did you do your test with the throttle wide open? Many newer gauges are terrible on accuracy, the fact that you don't have a lot of variance between cylinders and that it runs well and doesn't smoke I would just ride and not worry about it.
  5. Deathboner727
    Ohio
    Yeah made sure throttle was open. Saw a lot about cheap gauge tools. Might buy a name brand one or rent and test again. I appreciate the quick response guys thank you
  6. XJ550H
    many an XJ keeps running strong with lower than spec compression numbers.
    if your "low" numbers were all close to each other thats the important part of the test
  7. Jetfixer
    Try a different gauge and if it runs good just ride.
  8. SQLGuy
    SQLGuy Well-Known Member
    I got about 125 on mine last I checked. But I'm also at 6000 feet. I get about 52 MPG on long rides - usually in the mountains. Around town I average about 38 MPG.
  9. chacal
    So you're actually at about 150psi, which is a very happy place for your engine:
    XJ650 and XJ750 air-cooled engines:
    Minimum: 128 psi
    Standard: 156 psi
    Maximum: 171 psi
    Max. variance between lowest and highest: 14 psi
    NOTE: for readings taken at locations that are above sea level (ASL), the following correction factors should be applied to the readings that your gauge obtains:
    - 500' ASL, multiply your readings by 1.013 to get a "true" compression reading.
    - 1000' ASL, multiply your readings by 1.029 to get a "true" compression reading.
    - 1500' ASL, multiply your readings by 1.042 to get a "true" compression reading.
    - 2000' ASL, multiply your readings by 1.060 to get a "true" compression reading.
    - 2500' ASL, multiply your readings by 1.072 to get a "true" compression reading.
    - 3000' ASL, multiply your readings by 1.093 to get a "true" compression reading.
    - 3500' ASL, multiply your readings by 1.103 to get a "true" compression reading.
    - 4000' ASL, multiply your readings by 1.126 to get a "true" compression reading.
    - 4500' ASL, multiply your readings by 1.136 to get a "true" compression reading.
    - 5000' ASL, multiply your readings by 1.160 to get a "true" compression reading.
    - 5500' ASL, multiply your readings by 1.172 to get a "true" compression reading.
    - 6000' ASL, multiply your readings by 1.196 to get a "true" compression reading.
    - 7000' ASL, multiply your readings by 1.233 to get a "true" compression reading.
    - 8000' ASL, multiply your readings by 1.272 to get a "true" compression reading.
    Also, be aware that barometric pressure differences (during testing events separated by more than just a few hours) will cause changes in indicated compression readings. Atmospheric pressure can vary significantly over time at the same altitude, due to weather systems….you hear this on weather reports, where the forecaster is talking about “High” and “Low” pressure systems. Basically, higher atmospheric pressures translate into higher indicated compression pressures. Although it is rarely of major consequence, in order to be "dead-nuts" accurate you should also record your local barometric pressure at the time of each test. If you measured compression on a day when it was 1030mbar and observed 150psi, and then took a measurement later in the week/month/etc. when the ambient air pressure was only 990mbar, that’s an environmental air pressure difference of about 4%, and assuming nothing else had changed you would then read a 4% less compression pressure of only 144psi......
    Deathboner727, Furman and SQLGuy like this.
  10. Deathboner727
    Ohio
    Went for a spin to the hardware store today. Last stop sign I noticed some smoke coming from front end. I didn’t think much of it til I made it home. Left bike running and inspected front of engine and saw oil leaking from valve cover gasket. Removed cover to replace and noticed this unfortunately. Is this part interchangeable?
  11. chacal
    Well, depends what you mean by "interchangeable"................also, can't tell which cap it is. Those "short" caps can either be a bearing cap or a non-bearing cap. Non-bearing caps can be swapped between engines with no issues; bearing caps are, theoretically, "married" to the cylinder head that they came on, because the cap and its saddle (in the head) are bored together and thus are "mates". However, in reality, you can (and have no choice but to) substitute a cap from another engine, and then check clearances with plastiguage, etc. to make sure that there are no problems, and if there are problems, that they aren't going to be of the semi-catastrophic kind.
    Deathboner727 and Chitwood like this.
  12. Deathboner727
    Ohio
    How can I tell if the cap is bearing or non bearing? There are two caps that this has happened to. Both are the smaller ones located on the right side of both cam roller sprockets. Was considering replacing the entire head. Was able to track one down that comes with matching cams. Was just curious if this could be a quick fix i guess. Whats the worst case scenario of swapping caps?
  13. Deathboner727
    Ohio
    Sorry forgot to ask what tolerances should i be looking for with a plastigauge? I will remove them tomorrow and post some pictures for more information thank you!
  14. fastenova
    Redmond, OR
  15. Deathboner727
    Ohio
    Having cold start issues. There’s spark on all plugs. Once bike is warmed up no starting issues. Thoughts ?
  16. Timbox
    Have you cleaned those carbs yourself? Broke them down sense you have owned the bike? Most of the bikes that we pick up even if they are running, need to have the carbs run though by the current owner.
  17. XJ550H
    enrichment circuit may be plugged , the enrichment wells in bowls may be plugged. or pilot jet circuit may be clogged
  18. XJ550H
    HCP22924 Aftermarket camshaft journal NON-BEARING CAM CAP. On many engines, on the right side of the cam tunnel opening there is a non-bearing camshaft cap. Unlike all of the other cam caps, which actually hold the camshaft down to the head and actually have smooth bearing surfaces……the only purpose for this cap is to supply a threaded hole to accept the valvecover hold-down bolt. This same cap is used on both the intake and exhaust cams, and is on the right side of the cam tunnel opening. NOTE: on the left side of the cam tunnel opening, there is a very similar-looking cap (also with a valvecover bolt acceptance hole), but that cap is an actual bearing cap. This replacement non-bearing cap, although similar, cannot be used in place of that actual bearing cap. This non-bearing cap is easily cracked and broken if its valvecover bolt is over-tightened. And unlike the original cast aluminum cap, this cap is machined from a billet of high-strength T6061 aluminum and features a much stronger profile than the original cap. Fits all of the following engines on both the intake and exhaust camshafts: XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, 1984-91 XJ600 Euro, all 1982-83 XJ650 Maxim (YICS) engines, all XJ700 air-cooled, all XJ750 air-cooled, and all XJ900RK, RL, N/FN, and F engines. NOTE: XJ900 engines actually use 4 of these non-bearing caps, located on both sides of the cam chain tunnel. Each:
  19. Deathboner727
    Ohio
    I’ve already replaced caps and checked tolerance with plastic gauge. Took them awhile to find at autozone lol. I’ve done lots of cleaning on these carbs. There was one pilot jet with partcial blockage. I removed air fuel screws and discovered more partial blockages. Bike starts better on cold start. Idles way better. I synced the carbs were off slightly. Still curious cause the bike would start right up. There has been some small electrical issues. If the shifter is slightly touched lights dim. The voltage regulator seemed pretty warm after syncing carbs today. I replaced stator plug connectors because they were melted last year. New battery fully charged. Voltage tested good loaded and unloaded. Rpm test showed 13.25. Not real sure were to go from here? Maybe check startor brushes ?
  20. XJ550H
  21. Deathboner727
    Ohio
    You are right I removed cover and saw brushes are below 11mm one was shorter then other also. Will replace and keep ya updated
  22. XJ550H
    it is normal to have 1 brush wear shorter than the other due to distance travled on the copper rings per rpm
  23. Deathboner727
    Ohio
    There was a lot of resistance went testing stator. Regulator passed diode test. Replaced stator and brushes today. Hoping to fire up soon to test charging system
  24. Deathboner727
    Ohio
    Installed new stator and brushes. Alternator is putting out 12.6 volts while reving. Not sure where to go from here. Rectifier passed diode test.
  25. Deathboner727
    Ohio
    Throttle hesitation thoughts? I have to ease acceleration. There’s no backfiring. Will bog for a sec and then boom !
  26. k-moe
    Were the carbs fully disassembled, cleaned, the old rubber parts replaced, fuel levels set, and then bench synched?
  27. Rooster53
    Did you get the charging system working?
  28. Deathboner727
    Ohio
    Affirmative my learning computer is much stronger
  29. Deathboner727
    Ohio
    Affirmative
  30. Jonarmstrong
    Jonarmstrong New Member
    Detroit Michigan
    Have you or anyone else actually ordered this part I’m interested but hesitant because no images and very little information like reviews or anything. Really want to get this bike back together
  31. hogfiddles
    I guess you DON’T really want to get your bike back together......I still have the part sitting here.... I’m putting back in the engine now so I don’t lose it.
    jayrodoh likes this.
