HeLP!
Discussion in 'XJ Technical Chat' started by MadMaxim85, Jun 11, 2009.
  1. yamaman
    yamaman Member
    Staten Island, NY
    which little port? got a pic?
  2. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    You know how you unscrew the float bowl screw to drain the carb well? On carbs 2 & 3 the outlet port is blocked by what appears to be plastic (or something.) Fuel comes out the float bowl drain screw hole.
    I'll take a pic tomorrow.
  3. RickCoMatic
    Get an Inline FUEL Filter working for you.
  4. meister66
    meister66 New Member
    Gas tank sealer ? Is the inside of the tank clean ?
  5. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    Nope, as far as I know, no sealant. So those ports should be open. It's okay to poke them with a sharp object to open them up?
  6. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    Already got one. Thanks goodness. The fuel line I bought (3.99 a foot!) started degrading (it had a blue inner core) and I could see little pieces of it inside the fuel filter. But I changed that out and was still having trouble.
  7. bigfitz52
    If there are little pieces of it inside the fuel filter there are much tinier remnants in your carbs, betcha anything.
    If the carbs WERE TRULY clean; pull the rack and yank the float bowls, flush/blow everything out REAL WELL, replace the bogus fuel line everywhere it's fitted; clean out your petcock (it's upstream of the fuel filter) and hope for the best.
  8. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    Luckily, I only used one small piece (between petcock and fuel filter). The rest was used on my aux gas tank setup. Carb bits have been soaking all night in carb cleaner. I had about a foot of decent fuel line that I am replacing the other bits with. However, I didn't see any of the blue bits anywhere inside the carb, just inside the fuel filter (yay!) but am cleaning them out anyway.
    That weird amoeba creature tho... that was odd. I'm trying to decide a name for him.
  9. chacal
    Jose Cuervo............? 8O
  10. coachholland
    coachholland Member
    Georgetown, KY
    There are several little tubes within the carbs, so I'd like to see what you're referring to before I say go start poking. A simple carb soak, boil, whatever isn't going to clean your carbs if the ports are blocked.. sometimes you need something to actually get in there and clean them out. On the really small ones, I used guitar string to clear the passages. Once you spray carb cleaner through those passages and the stream comes out nicely out the other side, then you know you truly have them clean. If nothing gets through or only a little gets through, then they sare still blocked. Those carb cleaner, guitar string and compressed air to blow through the passages comes in very handy when cleaning your carbs.
    So did it start spraying directly in with the carbs off?
  11. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    I don't know what that crud was, but after poking it with a special tool I have, the stuff came right out. It was a mix of some white stuff (almost like the consistency of dried polishing compound) and dirt.
    The good news is, IT STARTS! IT RUNS! It still needs a good tuning, but for now, the bike is on the road.
    I posted a video on my blog. Check it out!
    And thanks to everyone who made suggestions. Over the next week, I am going to be working to get it 100%, but I'm happy with the 96% for right now.
  12. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Good job! Sounds great! That hangin idle is an air leak of an unsynced carb. Got the 2 glass bottle method??
    We have the same bike, but for some reason it looks smaller than mine on your video! Maybe its my imagination.
    Oh well, enjoy riding sir!
    -Christoph
  13. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    air leak? Could explain the poor sync results I experienced. Check my blog (haven't figured out how to post video here yet... but I will.) For now, here's a photo. I'm not sure why #3 is causing me so much difficulty, but as you can imagine, it makes it tough to sync correctly.
    Ideas?
      File size:
      53 KB
      1,864
  14. RickCoMatic
    Major AIR Leak preventing Manifold Vacuum at Intake Manifold.
    Where the Intake Manifold seats to the Cylinder Head MOST LIKELY.
    O-ring Seal aged and no longer Air Tight.
    (Seal the Manifold to the Head with a Smeared-in Bead of RTV Sealant all around the Manifold)***
    ***Removing the Manifold RISKY if Cap Screws are seized. High Probability.
    Other factors:
    Bad Manifold or Shaft Seal Air Leaks
    Rings
    Valves
    Worn Cam Lobe on 3
  15. SLKid
    SLKid Active Member
    That is a really really cool meter!! I want one!
  16. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    I've looked, and it appears to be a tight seal. Can I use propane or starter fluid safely here to test?
  17. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    That's a Morgan Carb tune... awesome piece of equipment.
  18. chacal
    Guess who carries them in stock......... :D
  19. RickCoMatic
    Do you have that Gauge hooked-up 1, 2, 3, 4
    Or is the Photo right: 4, 3, 2, 1 ???
  20. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    1 is on the far left, correct? (following the coil numbering) but it seems to be backwards when it comes to the carbs (which are imprinted 4,3,2,1 in that order.) If that's the case, then the port on the manifold that is open for the tank vacuum is #2 (2nd port over from left). I assumed, perhaps wrongly, that cylinder 3 is the one with issues, when in fact it is cylinder #2.
    Why does this have to be so confusing?
