Here's the wiring mods to remove the rectangular instruments
Discussion in 'XJ Modifications' started by cturek, Oct 25, 2009.
  1. hogfiddles
    Well, I can totally appreciate all the effort going into figuring out the conversions, but I don't care at all for the look of the 750 Seca without the cluster nor the round light.
    As far as the '85 cluster....... You ARE aware that cluster is for a Maxim X, right? Also, for all the trouble, why don't you make sure to use gauges that are not faded out?
  2. Dave Johnson
    Dave Johnson Member
    Oak Grove,Minnesota
    Yes, I put the 85 X forks and instruments on the 82. Yeah faded, but it's what i have. It took awhile to realize I wouldn't need the temp gauge. Maybe I'll put a clock in there. Hogfiddles, I messaged you about your shim pool.
  3. Mustang
    Mustang Member
    Masonville
    Why couldn't I find this 6 months ago, I went through the process of getting a wiring diagram cutting wires and making it work
  4. William Firstbrook
    William Firstbrook New Member
    White rock British Columbia
    Great job on the bike mate I'm going for the same look did you find any engine problems when you disconnected the atari I tried to do the same thing defiantly not as well as you but if the atari wasn't connected the engine wouldn't run right. Is there something that needs to be bypassed?
  5. k-moe
    He hasn't been on since 2013. See my reply in the thread where you originally asked this question.
  6. John Michaely
    John Michaely Member
    Old forge pa
    I need some help guys I did exactly what the diagram showed me to do and now my tail lights are on constant and I still have no brake glow
  7. k-moe
    You swapped the brake and taillight wires around.
  8. John Michaely
    Old forge pa
    OK maybe you can be able to explain which wires should be tied together I have the y-y/g the g-g/r and the b-b for the brake and the l-lw for the tail light
  9. k-moe
    Did you jumper G/Y to Y/W on the 6-pin connector? That's the brake light circuit. B-B (same connector) is for the headlight.
  10. John Michaely
    Old forge pa
    Ya I jumped them together
  11. John Michaely
    Old forge pa
    All the lights are on soon as I turn my ignition on head tail and brake
  12. k-moe
    Hmmm......
    Is there evidence of wiring modifications that were "gifted" to you by a previous owner?
    I think it's time for you to start a thread for your bike if you haven't already, so we don't clutter this thread up.
  13. Bo.
    Bo. New Member
    Arizona
    That picture of the wires you changed, is that the ONLY wires you needed to alter?
  14. Timbox
    Timbox Well-Known Member
    Bo, have to done all the reading in K-moes signature yet? If you have great! If not take the time it will really help out.
  15. k-moe
    All the wiring changes are covered in his first post. If you've done that, and are sill having problems, then something else is wrong. Please start a thread if you have not already.
  16. AndyC
    AndyC New Member
    Sylvania Oh
    Awesome, I am in the middle of fixing a barn find and I think the info here will guide me well. I have a few questions and since this is an older post not sure if I’ll get an answer but here goes. Could I just use pin connectors to tap into the harness instead of making any cuts? I wasn’t sure.
  17. XJ550H
    you can buy the pins and mating connectors from our supporting vendor and do the job with out cutting wires.
    logo in upper right corner of page.
    or www.xj4ever.com
    or this thread
    XJ4Ever - Supporting Vendor
    you can also just start a conversation with him Chacal is his name even has the crimping tool you can rent if needed
  18. myhomework8mydog
    myhomework8mydog New Member
    Saskatoon
    Sorry to dredge up ancient artifacts from threads gone by but anyone know why the pictures from earlier posts here wont display anymore? They worked for me a few weeks ago. Doing the Atari delete and would like to reference some of those photos.
    Thanks!
  19. k-moe
    Which images specifically? I'm seeing all of them but a few.What browser are you using?
  20. XJ550H
    in chrome i see all photos except a few posted by Rickomatic on first page plus a broken link he posted for ilumanited tach.
    IIRC rick deleted his photobucket account when Photobucket had there change of displaying on certain web sites
