High Idle When hot
Discussion in 'XJ Technical Chat' started by mellicott, Nov 19, 2017.
Tags:
  1. mellicott
    mellicott New Member
    Florida
    Hello everyone,
    This is my first post, I just bought an 85 Maxim-X about a month ago. It's been great, with a few issues that were easily resolved. Now it is doing this high rev (about 3K RPM) thing where it's like the throttle is stuck. It's only doing it after it gets good and warm, about 5 miles or so. Once it gets hot, like 10 miles plus it starts doing it worse and higher RPM's. It starts to climb by itself, but if I let the clutch out a little when stopped it brings it back down. I can usually figure this kind of thing out, but so far no answer. Other than this it seems to run like a beaut.
  2. wgul
    wgul Active Member
    Boston
  3. hogfiddles
    1.Vacuum leak
    Or
    2. Adjust your idle speed knob
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Or the fuel level in the bowls is too high.
    Gary H.
  5. hogfiddles
    I wouldn't jump to that right away......
    rocs82650 likes this.
  6. Jetfixer
    ^^^+1 Vacuum leak. when hot and doing this spray some carb cleaner around carb boots if RPM picks up there is leak. What condition are boots in are they cracked? Have you had carbs off recently? are you running stock airbox or PODS?
  7. Robb
    Robb Member
    Bolingbrook, IL
    I had this happen last spring. Idled fine, then after 15 or 20 minutes up to 3g's. It ended up I had removed the exhaust and when putting back on had forgotten to tighten the nuts on the #4 exhaust. Whacked the side of my head with my right palm, tightened it up and has been fine ever since.
  8. Retromoto
    Retromoto Member
    Des Moines
    If you spray carb cleaner around the boots, also shoot it around the throttle shaft. Butterfly seals on the shafts can sometimes crack and cause leaks.
  9. Simmy
    I have experienced this and cured it with the mixture screws and carb synch. Slipping clutch at a stop brought it back down, same as you describe.
    Stumplifter likes this.
