Homemade fuel level adjustment YM-01312 tool and adapter for Mikuni carbs
Discussion in 'XJ DIY How-To Instructions' started by mark1911, Apr 15, 2021.
  1. mark1911
    mark1911 Member
    liverpool uk
    OK, so further to the post I managed in the end to make a homemade adapter for the carb bowl thanks to the previous post. Found in my shed electrical butt connectors but they at each end were to slightly big to fit the drain hole so simply chopped of the end with a blade and used a small hammer to tap the connector home into the hole. After that all you require is attaching the butt connector to the tube which I used from a brake vacuum pump which was sacrificial and there you have it a nice simple gauge for you to measure your float fuel level. IMG_20210415_152621.jpg IMG_20210415_152646.jpg IMG_20210415_152700.jpg IMG_20210415_152930.jpg IMG_20210415_153311.jpg IMG_20210414_153549.jpg
    Very nice. I will have to give it a try I have a few set of mikuni carbs I have to rebuild. I never would have thought of that, I was too focused on using automotive connectors for vacuum.
  3. chris123
    chris123 Active Member
    Benicia, ca
    Excellent idea!
    Hopefully others see this and can benefit. I was searching YM-01312 (keyword)
