Hooked battery up backwards, Now no sign of life
Discussion in 'XJ Technical Chat' started by Bob Salter, Feb 16, 2020.
  1. Bob Salter
    Bob Salter New Member
    toronto
    I mistakenly hooked a car battery up in reverse on my 82 650 Seca (new to me) I was told the bike turned over fine by the guy who sold it to me. Should have verified that myself, but the bike is a project that seems pretty good so far as I am digging in to it. At any rate, I made the current mistake, so I will assume that is the source of my problem. Any suggestions of what to look at as a first step to getting power flowing? Thanks.
  2. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I'd start with the fuses and fuse box. Then check the condition of the connectors in the starting circuit.
    Bob Salter likes this.
  3. Bob Salter
    toronto
    Thanks , will do.
  4. SQLGuy
    SQLGuy Well-Known Member
    What do you mean by "no signs of life"?
    Do the instrument cluster lamps light up when you turn on the key?
    If it's the original glass fuses fuse box, it needs to be replaced anyway.
    I am not sure anything is protected from reverse voltage in this system. Worst case could be pretty bad.
    Looking quickly at the 650G wiring diagram, I don't think the diode block would have been damaged. If it doesn't crank, then you probably had another problem already, like a bad solenoid, or just user error like the bike in gear, kill switch in kill position, ....
    I'd be most worried about the rectifier/regulator being fried, and also the TCI...
    Rooster53 and Franz like this.
