Hot bike = poor idle
Discussion in 'XJ Technical Chat' started by Fraps, Jun 10, 2008.
  1. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    I don't think I've seen this problem come across the forum before but I have been experiencing a problem with idling when my bike is warmed up.
    Usually after a nice 20-30 minute ride, the bike is fully warmed up, I will stop at a light and I can hear the idle struggling to remain steady. I find myself having to hold the throttle open slightly just to keep the bike running! If I let off, the bike will stall.
    After a stall, it starts up right away again but same problem. If it let it sit for ten minutes, then the bike starts up and idles fine until the bike heats up again.
    I have no idea where to even start looking to address this problem. I can't figure the carbs (mind you I'm no carb expert) since the bike runs fine initially.
    Any thoughts? At this point, I'm afraid to go anywhere on the bike for fear I can't get home!
  2. switch263
    switch263 Member
    Austin, TX
    i would venture to guess a sync and/or mix issue, my bike acts rather similarly. Runs very strongly, but after a bit riding the idle is unsteady just like yours.
  3. stereomind
    stereomind Active Member
    Tulsa, OK
    What color are the spark plugs?... I wonder if your pilots are set a tad rich.
  4. MiCarl
    Probably too rich on the idle mixture.
  5. Fraps
    Fraps Member
    I recently synched and colourtuned. Plugs are all tan. I did some tests last night at different rpms (2k, 4k, 7k) for 20 seconds each on the center stand to see how the plugs look. Always tan.
    Maybe I need to colourtune again with the bike fully warmed up? I'm not sure I did that last time.
  6. 85MaximXX
    85MaximXX Member
    S.W. michigan
    you could bump your idle up. IMO you should only adjust the idle speed when the bike is warm. Run it for 20-30 min then with your gloves on reach in and turn the knurled idle screw up to where you want it. You may have a little higher idle when cold but if all else is in order as you say with the plugs being a light tan you will be fine. Every time I have ever synced carbs I had to readjust the idle speed as well.
  7. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    I'm having a very similar issue with my 550 Maxim. After all I have done, checked, and adjusted lately I am beginning to think my butterfly shaft seals are going bad. I haven't been able to get a reaction spraying them with starter fluid, but I am getting the erratic idle which I have read may be a symptom of bad seals and I can see where fuel has previously lacquered around and under the C-clips. Sometimes you can see they are slightly wet, but never dripping.
  8. RickCoMatic
    What happens AFTER the light turns Green?
    How does the Bike get "Out-of-the-hole"?
    Does it accelerate without stumbling or hesitation?
    Does it cough a bit and then go?
    What exactly does it do?
    We need to know how the Bike accelerates "Off-Idle" to determine how much of an adjustment or other tuning there is to do.
  9. leadboots
    leadboots Member
    aylmer ontario canada
    remember to set the idle when the bike is warmed up
