Hot start issue
Discussion in 'XJ Technical Chat' started by tabaka45, Jun 13, 2026.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    85 xj700n. Starts and runs great when cold. If I stop and leave it for about 30 minutes hot it won’t start. Good battery and starter. What’s going on?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Kinked fuel line?
  3. tabaka45
    Brunswick, Georgia
    Don’t think so. Line looks good and it runs great once it starts. When it does this I can let it sit for 30-45 minutes and it usually fires off instantly.
  4. chacal
    Plugged gas cap vet? Or, if a Cali model....and still has the original emissions control system installed, something plugged in there or the "anti-rollover" valve.
  5. tabaka45
    Brunswick, Georgia
    I opened the gas cap and it popped once but didn’t start. Don’t think it’s a Cal model. How would I find out?
  6. tabaka45
    Brunswick, Georgia
    Just curious, could a close to lean setting of the pilot screws be an issue?
  7. cds1984
    I had a problem like that on my 750 originally.
    The turn off and won't start after a while.
    My problem was flooding when hot.
    The bike would start if I opened up the throttle a lot when cranking, kinda like flushing air in.
    Try that out.
  8. tabaka45
    Brunswick, Georgia
    Sounds like a possibility. Used to do that with old cars that flooded.
  9. tabaka45
    Brunswick, Georgia
    Think I found the problem. Although my battery cranked the engine well, it apparently didn’t have enough power to fire the plugs at the same time. When I finally put a meter on it I got just a little over 12 volts, but it dropped to about 9.3 under load. I had noticed that sometimes it tried to start just as I let off the starter button and that’s what led me to checking the battery. With it cranking the engine well I just assumed the battery was good. Lesson learned. With a new battery the issue seems to have been resolved.
    chacal likes this.
  10. cds1984
    Wow. Fine line on the voltage that's for sure.
