How to change engine oil and filter 1983 Yamaha XJ650 Maxim
Discussion in 'XJ DIY How-To Videos' started by Inder Singh, Nov 14, 2022.
  1. Inder Singh
    Inder Singh New Member
    Humboldt County, CA
  2. Simmy
    You forgot the washer between the spring and the rubber seal on the filter.
    Without it the spring can distort the seal and could leak there, bypassing the filter
  3. Wieserse
    Wieserse New Member
    Slower MD St Mary's County
    Good morning, just watched oil filter change, you stated oil filter orientation front towards engine? I recon front stamped in oil filter would be towards front of bike reverse of your take on the filter orientation….. seems like
  4. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Nice video but unfortunately it is not correct or accurate. As above, the washer between the spring and filter is missing. (Likely stuck to the old oil filter and thrown away). The oil filter orientation is incorrect, "Front" should face forwards away from the engine, not towards it. No mention of removing the middle gear drain plug.
  5. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
    o_O
  6. Melnic
    Melnic Active Member
    I am about to change the oil in my '83 XJ650 I have a XJ650K manual and it mentions the middle gear oil drain plug but when doing a bunch of reading, people say to just leave it alone as you have risk of breaking it.
    I can't even find mine. The manual picture gives no perspective of where the photo is taken and I can't tell where it is.
  7. Dan Gardner
    Minneapolis, MN
    Don't lose any sleep over it, @Melnic. Just change the oil and don't worry about the middle gear plug.
    The arrow in the photo below shows where the plug is from inside the engine:
  8. Dan Gardner
    Minneapolis, MN
    Here's the middle gear drain plug from underneath. If that engine was installed there would be plenty of frame and exhaust to work around or remove. That's why it's not worth it for a couple tablespoons of oil.
  9. DaygloDavid
    On my 1980 4K0 (UK) model, I used to remove the exhaust system to access the middle gear drain plug. Since then, had a tool made which now means it can be done without needing to do that. The plug has a coarse thread and has never been a problem to remove.
  10. Dan Gardner
    Minneapolis, MN
    That's interesting, @DaygloDavid . Could you share a photo of that tool?
  11. DaygloDavid
    Sorry, can't do a photo but basically, it was a 10mm 1/2' sq. drive socket with along reach allen key wrench adapted to fit the sq. drive using an allen bolt head which was filed square to fit the 1/2" sq. drive.
    Something like this. The dimension "h" needs to be 45mm to clear the frame tube and fit between that and the original 4-2 exhaust system collector box. The length of the allen key "l" in my case is 215mm. The allen key is ~10mm across the flats ("e"). "d" is obviously the 10mm socket which in the diagram is double ended. Hope that gives you a reasonable idea.
    Franz likes this.
  12. Melnic
