HOW TO: Clean the Enrichment Circuit Well
Discussion in 'XJ DIY How-To Instructions' started by Gamuru, Apr 6, 2008.
  1. RickCoMatic
    If you are losing a lot of time on Fuel Bowl with clogged Enrichment Well Metering Jets ...
    Substitute another Fuel Bowl.
    -Or-
    Drill-out the Jets.
    Order replacement Twist Drills from a Metric Supplier
    0.35 >38, 40, 45, 50, 52, 58, 60, 65, 70
    Ask for:
    "Number 70 through Number 80"
    Armed with those Drills ... Hit a Hardware Store and get a "Dremel Keyless Chuck"
    Use the Keyless Chuck to give you a "Grip" on the small Drill Bits and probe the Fuel Bowl Well with a Twist Drill.
  2. chacal
    I also carry the correct size starter jet clean-out drill bit in an extra-long length, so no need for the pin vise, just a pair of plier will do!
  3. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
    so... couldnt i just use a small guage unfolded paper clip to clean it out?
  4. RickCoMatic
    Don't waste time fooling-around with Fuel Bowl Enrichment Circuit & Well Metering Jets and orifices.
    Don't lose time.
    Don't get frustrated.
    Get a Twist Drill that fits the Port and use the Twist Drill to OPEN the Passages.
    Use the Twist Drill as a Hand Tool and probe the orifices for foreign matter and clear them out for spraying.
    If you spend more than two minutes working on an obstruction.
    Drill it.
    Before you get the drill, ... "Tape-off" the bit.
    Wrap the Bit with Masking Tape to its "SAFE Depth"
    Chuck it up.
    Drill-out the Passage Intersection.
    Keep-on trucking.
    Don't fool-around with the Fuel Bowl if its clogged.
    Attack it. Get the Passage open. Don't mess with it!
  5. ktcubed
    ktcubed Member
    St. Augustine, FL
    Rick,
    You wouldn't happen to know what size is the one that fits would you?
  6. bignewt72
    bignewt72 New Member
    Fort Drum, NY
    Thanks for all your help. I will check and see if the cleaning is what it was.
  7. scrubby
    scrubby Member
    bevent Wi
    Trying to clean the idle choke curcit on a HITACHI CARB # 33. Been threw it a few times the bodys are clean I ( of course ) thought I had it clean but the bowl is solid in the choke curcit. Used a torch cleaning set ultra sonic cleaned for 4 days pin drills nothing is getting the largs slug of crap out, it will not air check or move any cleaner threw it buy new bowls? and where can I get them I have another set of bowls here but they are going to another member and dont want to give him crap parts on a set of carbs mine are low low milage long time sitting
  8. scrubby
    scrubby Member
    bevent Wi
    Fourth time still not the charm put fuel in plug holes runs for few seconds then dies choke curcit clean jets clean can't get this time around I got alot of new parts to sell
  9. UK550Maxim
    UK550Maxim Member
    Bournemouth UK
    So glad I read through this, thought I had done a good job of cleaning my carbs but completely overlooked the enrichment well, 3 out of 4 are clogged! That' embarrassing given the number of times these carbs have been off. Note to self, read the bloody instructions FIRST once in a while!
  10. tcarr289
    tcarr289 New Member
    eastern nc
    Just a suggestion on what to use to get those stubborn clogs unclogged, a 6 in. length of guitar string in a drill works perfectly. it will not harm the carb but it will go throught pretty much anything that is clogging the passages.
  11. Douglas Watson
    Douglas Watson New Member
    Toronto Ontario
    any way to get the pics/video?
  12. k-moe
    Unfortuantely not, unless the Wayback Machine captured the pics. If you read the description with the float bowls in-hand it'll become obvious what to do.
  13. Douglas Watson
    Toronto Ontario
    I got it... Need to order a drill bit... the needle didn't work :)
  14. wgul
    wgul Active Member
    Boston
    Here I go digging up another ancient thread. For good reason tho. I just happen to be using the hyperdermic needle method yesterday but mine isn't needle sharp; it has a blunt end and works just fine when inserted into the passage. These are easy to procure since people (like me) use them to refill the ink in their inkjet printers. The needle can also force air into the passage too.
