How to Fork Cyliner Bolt Removal Tool
Discussion in 'XJ DIY How-To Instructions' started by Calvert, Apr 21, 2019.
  1. Calvert
    Calvert New Member
    United States
    Many threads on this topic using a hex bolt or inverted spark plug socket "of the appropriate size". But had to do some sleuthing to figure out what this size actually is and the simplest way to make something.
    The elusive measurement is 3/4". You could as the manual suggests take a hex head bolt, slide it through a socket with a nut attached, thus having a hex head on both sides.
    The inverted 5/8" spark plug socket is ideal having the the 3/4" hex at the bottom of the shank, but many do not allow the square drive to pass through the socket in the opposite direction.
    Solution:
    1. Find a sacrificial 5/8" spark plug socket.
    2. Whip out your trusty dremel, or cut off tool of choice.
    3. Cut just the hex portion off the bottom of the 5/8" spark plug socket.
    4. Sand the cut edge to remove any jagged edges.
    5. Voila! You now have a 3/4" hex head with a 3/8" square drive. Attach to as many 3/8" extenders necessary to reach the damper rod.
    You now have a custom tool for the next job if you don't lose it. Hope this helps some people out.
    Now to the hardest part.... Actually removing the old seals. Chime in if you've got a hack for that procedure.
    nice tool could use it with a very long extension. I use a little heat on the bottom bolt to soften the thread lock that is used.
    I purchased the fork tool from Chacal works great
    this is the set up used by Yamaha. Looks like a tire iron. also applying a little heat will soften the seal and remember to remove the spring clip before starting
    Calvert likes this.
  3. Calvert
    Calvert New Member
    United States
    I figured heat and some good leverage were in order for the task. Patience and persistence will get me through this build.
  4. Calvert
    Calvert New Member
    United States
    Thanks for that pic by the way. My tire iron was perfect. Heat, cushion, pry. Less than 5 minutes on a crusty old seal. Happy day.
  5. k-moe
    Interesting. Most of us just flip the socket around instead of cutting it, but not all sparkplug sockets let you flip them.
  6. Franz
    I cut an old car coil spring compressor l had which fitted my forks to slacken the damper. Never throw anything away it may be needed later that is what l do anyway.
  7. k-moe
    That last bit of advice is why my upcoming move is going to be expensive. Transport bills by the square foot of cargo.
    Franz likes this.
  8. Brian Harris
    Brian Harris Member
    Birmingham al
    I know this is an older topic but I found a super easy solution in case anyone runs into this in the future. I happened to have some 1/2 inch threaded rod and the appropriate sized nuts ( which are likely 3/4 inch ). I found that just using two nuts cinched together tightly on each end of a piece about a foot long worked perfectly and I was able to get some really seized up damper rod Allen head screws to come out with ease. I had an old bench vise and held an 8mm Allen key in it, placed the fork on top of the Allen key and used the Tool I made to spin to the damper rod bolt loose.
  9. XJ550H
    that works or a sparkplug socket inverted on an extension.
    I bolt the fork down via fender mounting holes to plywood a little heat because of the yamaha threadlock that is used and out it comes
  10. MTNPASS
    MTNPASS New Member
    Colorado
    I have read the posts to create a special damper rod removal tool with a bolt or socket, but my 1982 xj750 appears to have three slots in the fitting that is holding in the damper rod. Has anyone run into this issue? Any suggestions?
  11. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Here's a breakdown of all the parts in your forks and a view of the socket at the top of the damper rod. Not sure if those are the 3 slots you are referring to, but the damper rod can be held by the same method as the other models without the adjustable orifice. It's a 12 point 19 mm hex socket. A 3/4" nut fits it nicely. Use a piece of 1/2" all-thread and double nut it at both ends or the inverted spark plug socket and extensions.
    You can remove that circlip and disassemble the rebound adjuster if you want AFTER you remove the damper rod, but it really isn't necessary unless you find some nasty gunk in there.
    Don't try to remove the long, half moon rod from the top piece that the plastic knob screws into.
