How to remove intake rubbers
Discussion in 'XJ Technical Chat' started by Arnaud, Nov 4, 2024.
  1. Arnaud
    Arnaud Member
    Netherlands
    The intake rubbers/inlet manifolds of my 1988 xj900f show some rupturing (also in the inside)
    1 They seem reluctant to be removed.. does anyone have a tip?
    2 When i install the replacement, should i add an paper gasket between the head and the rubber?
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Remove the screws, know them off with a mallet. They have an o-ring for sealing against the new gaskets you install.
  3. Franz
    Hope you get them out without them shearing off the bolt heads.
  4. Arnaud
    Arnaud Member
    Netherlands
    So you have to get separate hat-resistant O-rings, okay.
    Indeed loosening the Allen bolts seem to be the problem?
  5. Timbox
    Lose of penetrating oil on them allen heads. Use a sharp flat strong blade to get between the two surfaces and slowly work around. If you want to reuse them, do it slow and not with so much force you will bend them and then cause air leaks when re-installed.
  6. Arnaud
    Arnaud Member
    Netherlands
    The reason why i want them off is because of ruptures, also on the inside?
    Hmm so no quick repair then...
    New ones are around 100 euro's. From China a lot cheaper.. did anyone dare this?
  7. Huntchuks
    East Rochester, NY
    Some have bad experiences with Chinese boots. From falling apart to vacuum tubes falling out.
  8. Timbox
    Does that go all the way through? If I were cheap and I am....lol, I would use a soldering iron and see if I could coaxs them back down and seal that are. That or a flat screwdriver that has been heated up with a torch. Just a thought.
  9. Franz
    Will it work?
  10. Huntchuks
    East Rochester, NY
    Doesn't look leak proof to me!
    Franz likes this.
  11. Franz
    It will be as good as the Chinesium intake stubs. I wonder if the stubs could be cut where the bolts are just to free them (without damaging the head of course) and then use a Mapp gas torch on the bolts, get them very hot before trying to remove them. Use a Dremmel or something like that. Just an idea?
  12. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i did exactly the same ,using 4" heat shrink tubing, but did a better job than in that video, he's overlapped it too much , i cut mine short of the mounting flange, and also used black silicone sealant ( rtv, i think you call it) around the round stub before shrinking it
    Franz likes this.
  13. Franz
    When did you do that?
  14. bensalf
    yorkshire ,england
    it was on my cafe racer build i did about 2014
  15. bensalf
    yorkshire ,england
  16. Franz
    Oh I remember it now nice machine you did a great job of that build.
  17. bensalf
    yorkshire ,england
    intake boots bit is on end of page 3
  18. Franz
    Do you still have the bike? Using RTV to fill the cracks and then the tube. I would do that before buying the Chinese stubs. If he uses the soldering iron as @Timbox stated and your solution that is better than snapping the bolts. Going to real your build again later. No wonder it took a long time to polish your engine cases. Great work.
  19. Arnaud
    Arnaud Member
    Netherlands
    Really, then i will think spend some money on the real thing..
  20. Melnic
    Melnic Active Member
    My biggest fear when removing anything on the intake or exaust side.
    I have been learning how to stick weld so that I can get them out when that happens. Now that I can stick weld, I'm certain it will NEVER Happen!
  21. Franz
    It is not just the bolts snapping that's bad but if the head has to be removed for a machine shop to remove them that's worse. I got the welder too.
  22. bensalf
    yorkshire ,england
    yeh, thanks, i still got the bike, its hardly turned a wheel since i built it, but thats gonna change next year after i get it back on the road over winter.
    been too busy building my other 2
  23. bensalf
    yorkshire ,england
    sorry pictures were supposed to be thumbnail o_O
  24. Franz
    Did you modify the exhaust before the silencer on the green one?
  25. bensalf
    yorkshire ,england
    yes i had the middle 4 into 1 custom made, headers are original ,silencer "if you can call it that" is just a off the shelf classic silencer
    i converted entire electrics to digital and LEDs all round
  26. Franz
    Looks good. I might convert my bike to Led one day. I was reading more about the red framed bike I did not know you could the pressure switches for the brake lights. I like the air box alteration too, how does it run with the Honda oil filter in there? Good use of the space below the seat too. Did you do the welding for the monoshock mounts and the chain guard? Looks awesome.
  27. bensalf
    yorkshire ,england
    it seemed to run just fine, i only did around 200 miles on it,
    my brother did the welding on the frame , as the chainguard is aluminium i had to take it to a local fabricator to weld up, i did the grinding and polishing after
  28. Franz
    I think you will win prizes if you put your bike into shows. Great build.
