how to remove oil pickup screen?
Discussion in 'XJ Technical Chat' started by seca550RK, Mar 29, 2020.
  1. seca550RK
    seca550RK Member
    spring city PA / Trondheim Norway
    Hi,
    I am riding an xj600 (FJ600 in the states)
    I had a clutch bearing fail, so I decided to drop the pan to look for any parts that fell through the hole. I thought I would give the screen a quick clean but I don't see how to take it off. Does anyone have any idea? It looks like it is pressed on, but I was afraid to use force on it.
    Anything else I should do while I'm down there? It looks like the o-rings on the pressure relief valve and oil level sensor are ok.
    A word of advice: it's easy enough to drop the pan, but scraping the gasket off of the upper surface isn't easy, even with a lift. o_O
    Thanks, Michael
  2. Toomanybikes
    Tsawwassen bc
    Screen snaps on and there is a bolt behind that to remove housing.
  3. seca550RK
    seca550RK Member
    Thanks, that's what I suspected. Do you need to use a screwdriver to pry it off?
