HSC32 Carb Rack Bench Stand
Discussion in 'XJ 3D Printing & STL Files' started by Dan Gardner, Mar 1, 2025.
  1. Dan Gardner
    Minneapolis, MN
    I designed this stand because I was sick of having carb racks and carb bodies rolling around the bench.
    I glued on some numbers so that I could keep my bearings straight whichever way I was looking at them.
    With the little spacer block added they work well for holding bare carb bodies:
    And it turns out nice for holding them on the shelf too:
  2. Tristan Kernick
    Tristan Kernick Active Member
    Pittsburgh, PA
    That is totally awesome. I wonder if I could drill holes for the drain ports and use this for setting fuel levels. Provided I could level the bench it sits on, of course.
  3. Dan Gardner
    Minneapolis, MN
    You could probably make it work - but anything worth engineering is worth over-engineering. So I have a different solution for that.
    This monstrosity is designed to hold the rack while wet-setting the fuel levels and allowing access to remove the bowls and adjust the floats:
    https://www.xjbikes.com/forums/threads/hsc32-carb-stand.131543/
    Tristan Kernick and Franz like this.
  4. Tristan Kernick
    Pittsburgh, PA
    Well how bout them apples. Should’ve checked through the other posts too. I built a makeshift carb rack out of PVC pipe when I set my fuel levels. It works, but it’s fiddly and hard to level properly. Yours looks like a way more elegant solution.
  5. k-moe
    This is interesting, I think that an iteration that allows for Pyrex measuring cups to be used for wet-setting the carbs would be advantageous. The rig I built from scrap wood and old intake boots (engine side) was economical, but not as elegant. The PVC stands also leave something to be desired if you're doing anything more than working on your own carbs.
  6. Dan Gardner
    Minneapolis, MN
    I’m having trouble picturing the idea @k-moe. How would you envision that working??
  7. k-moe
    Making the whole thing taller, and bringing the front and rear faces out further below the lowest part of the carb body so there is room for a measuring cup to fit in the carb holder.
    One of the advantages of building a rack holder out of PVC and used intake manifolds is that the entire lower portion of the carbs have plenty of room for pyrex measuring cups, and to be worked on by simply rotating the PVC pipes up to flip the carbs over.
    I'm a bit sick this weekend, but I'll try to make time to draw up a sketch of what I'm thinking once I'm feeling better. Hopefully by next weekend.
  8. Dan Gardner
    Minneapolis, MN
  9. k-moe
