HSC32 Carb Stand
Discussion in 'XJ 3D Printing & STL Files' started by Dan Gardner, Jan 23, 2023.
  1. Dan Gardner
    Minneapolis, MN
    Why spend $20 at the hardware store when you can spend $20 on filament and way too much time in CAD?
    I built this 3D-printable carb stand for HSC32 carbs.
    It is printed in 9 pieces and glued together.
    There are 7 STL files in the ZIP file.
    The "Leg" and "Post" pieces are the same left and right, and 2 of each will need to be printed.
    Here is the completed stand, painted in a snazzy orange, because:
    1. Protect it from solvents and chemicals in the shop
    2. Easy to find if you drop it in a snowbank
    3. It looks cool
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    That’s pretty awesome!
  3. Franz
    Brilliant looks great.
  4. Melnic
    Melnic Active Member
    That is neat, I will say that all I do is lean it up against a piece of wood I have. Shim with post its to make level. You can shim the carb, the wood or the table it is all sitting on till level.
  5. Simmy
    or a level and a vice.
    Not as shiny though.
  6. REUBEN
    REUBEN 1985 XJ700N (NOT PICTURED) Premium Member
    Midwest United States
    OK, dummy question. I need to know the ID of the carb holder.... holder holes... yeah. So I can match with my ID of the HSC33's off my '85 XJ700N. I don't know how to read the file to get those numbers.
  7. Dan Gardner
    Minneapolis, MN
    The ID of the holder (for the OD of the HSC32 carbs) is 38.5mm.
    Let me know if you want the FreeCAD file.
  8. Dan Gardner
    Minneapolis, MN
    FreeCAD file attached in case anybody wants to tinker with it.
    It is parameterized, so in theory one could tweak for different carb diameters and offsets.
    I think I have a junk HSC33 body laying around - I could also probably tweak for 33's.
    Oblivion likes this.
  9. Oblivion
    Oblivion Active Member
    Northeast Illinois
    Did you paint it or are your prints that smooth and glossy??? What material did you use? I'm not likely to print one, but I'm glad you shared.
  10. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Adjustable feet for leveling would make it perfect.
  11. Dan Gardner
    Minneapolis, MN
    I printed with garden variety PLA. Primed and painted for fun using some Kawasaki orange.
  12. Dan Gardner
    Minneapolis, MN
    I put on little rubber feet for stability. Something adjustable is a good idea. I will see what I can find
  13. Oblivion
    Northeast Illinois
    LOTS of hits for 'leveling feet' on Thingiverse.
  14. chacal
    And a cheap little bubble level you can screw or glue to the top rail..........so you know how much levelling to do.
  15. Antothoro
    Antothoro Member
    Anybody have a rack of Mikuni BS28 to compare against on this?
  16. Dan Gardner
    Minneapolis, MN
    Maybe I will ask @hogfiddles if he has a junk BS28 rack that I can borrow to tweak the design. Heck, if anybody has a rack that they want me to customize for I'd be happy to do it if you sent me a rack. I could then return your rack with a print!
  17. hogfiddles
    Just saw this… I sent you a text—
  18. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    Now I just have to learn how to use the 3D printer that I bought in 2017... :D
    Huntchuks likes this.
