I have a problem with My maxim X 700 XN 1985 model, it is hard to crank when the engine is hot,
Discussion in 'XJ Technical Chat' started by Arlan Casimero Rufon, Oct 15, 2020.
  1. Arlan Casimero Rufon
    Arlan Casimero Rufon New Member
    Galveston Texas
  2. Arlan Casimero Rufon
    Galveston Texas
    Is it true that ignition coil is the issue here because the resistance is getting low when the engine is hot?
  3. Toomanybikes
    Tsawwassen bc
    Coils are a common problem but also worn out starter brushes.
    Franz likes this.
  4. Franz
  5. Arlan Casimero Rufon
    Galveston Texas
    And also the engine died if i dont hold the throttle, even when i put the idle up.
  6. Toomanybikes
    Tsawwassen bc
    Have the carbs “been to church “ ?
  7. k-moe
    How long have you had the machine, and what maintainance have you done?
    Have the valve clearances ever been checked during the time you've owned it?
  8. Arlan Casimero Rufon
    Galveston Texas
    Its been a junk for 10 years, No Starter, no CDI, No rectifier regulator, No harness , i also change the cylinderhead gasket. One of the carb leaks the 1st one. Valve clearance has been check 3 months ago.
  9. Arlan Casimero Rufon
    Galveston Texas
  10. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Oh, that's hard to look at. Where did all the missing parts go?
  11. k-moe
    If there is no starter how the heck are you cranking the engine over?
    Also, why is there a starter in the last photo?
    Which photo shows the machine in its current state of repair?
  12. Arlan Casimero Rufon
    Galveston Texas
    That starter is not working when i bought that bike, the 1st owner sell the CDI and rectifier maybe, and they cut the harness, so i bought all that missing parts in ebay just to bring it back to life.
  13. Arlan Casimero Rufon
    Galveston Texas
    The 1st photo is in current state of repair now, the 2nd photo is the day that i bought the bike 2 years ago,
  14. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    What a radical before and after! Lovely.
