I just purchased a YX600
Discussion in 'Hangout Lounge' started by ZedTeam, Aug 30, 2026.
  1. ZedTeam
    ZedTeam New Member
    USA
    Hello, I just purchased a 1990 Radian as a project bike. I hope i am in the right place !
    Odometer states about 84k, but the speedometer doesn't work. So no clue on actual mileage.
    Motor starts easy and holds idle pretty well. transmission seems to be ok.
    Its going to need some work, but thats why i got it !
    I already have a long list of things to fix before i can get out on the road...
    Tires, Airfilter of some type, Petcock needs a vacuum line to work properly, brakes, lights, etc....
  2. Timbox
    Welcome to the forum. Congrads on the bike. Lots of great folks here to help you with any questions you might have.
    Is the bike a running machine? Going through those carbs might be a good first project. Not having an air box also might be interesting. Constant velocity (CV) carbs like to have an air box to run right.
    Keep us posted on your progress.
  3. ZedTeam
    ZedTeam New Member
    USA
    The bike is running. Starts up quick and seems to hold an idle. The missing airbox is going to be interesting. I can go buy one , but i am going to try and 3d print something.
    I was able to ride around the block a few times and shift through the gears. Its not safe enough to go fast ( old tires, iffy brakes etc).
    I have a box of parts to go through, but none are the air box ( and i noticed some are for a different bike )
    Right now i am trying to get the petcock off. The tank has some leaks that need to be addressed.
    Tomorrow i am going to get the title transferred into my name, assuming that goes OK i will be diving into the bike to make it rideable again :)
    Timbox likes this.
  4. ZedTeam
    ZedTeam New Member
    USA
    I went and got the title paperwork taken care of. Oil changed and i am starting work on the gas tank.
    There are some pin hole leaks in the gas tank i need to repair.
    The bike starts up really quick and idles ok, but after giving it some throttle the idle remains high. I noticed the throttle cable housing is broken where it goes into the throttle housing on the handlebars. So thats the next little project.
    Meanwhile, i am keeping an eye out for a stock air box, and exploring options to 3d print one. If anyone knows a .stl someone already made for the airbox... that would be awesome :)
    Timbox likes this.
  5. ZedTeam
    ZedTeam New Member
    USA
    Stock air box installed. That was a real pain to do. It starts up quick, but is idling high. I havent dug into it yet to find our why. I suspect there are vacuum leaks/ parts missing. I did find out it was a California model. I intend on removing the CA emissions stuff, but i want things running well before i start changing things
  6. ZedTeam
    ZedTeam New Member
    USA
    Well, progress has been made.
    It now runs on 4 cylinders instead of 3. No 1 carb was gummed up. I also think i found where every hose etc goes . This has CA emissions stuff.
    Brakes suck, but new pads are on the way.
    Aftermarket speedo/Tach installed. Old ones were broken.
    7 inch LED round headlight installed.
    I have done a few slow test rides around the block and i think i am going to really like this bike. It seems comfy enough. Feels very peppy , even with me being very cautious and it not in the best of shape. And it should look nice once i get things sorted out.
    Fuller56 likes this.
  7. ZedTeam
    ZedTeam New Member
    USA
    New tires put on, and a replacement cover for the stator/generator installed. I might be able to get out on the road next weekend !
  8. Fuller56
    Fuller56 Well-Known Member
    You have enough posts so now you have to post pictures of the bike. Congratulations on rehabbing another old bike and saving it from the ingraciousness of the scrapper.
  9. Timbox
    When you changed over the tires did you check the rear brake? Just make sure the glue on that pad is good and that the brake pad is secure to the metal portion it is sitting on. Shakedown rides are great, hope it goes well for you. As @Fuller56 mentioned, we need more pics of the progress. Good job and hope you love the bike.
  10. ZedTeam
    ZedTeam New Member
    USA
    Whoops, i should of said i changed the front tire only. It took awhile and it was getting late. My little 3 gallon compressor barely does the job.
    I will inspect those pads this weekend when i do the rear. TY for the reminder
    I will take some more pics this weekend. It doesnt look pretty... at all... but i like it :)
    Timbox likes this.
