I screwed up
Discussion in 'XJ Technical Chat' started by Mookymax, Jan 11, 2022.
  1. Mookymax
    Mookymax New Member
    Evansville, IN, United States
    I was attempting to rebuild the carbs on my 82 xj650. When putting a new idle mix screw on carb 3 I torqued too hard and snapped the head of the screw off. I tried to drill it out but that made things worse and damaged the venturi where the little needle hole is (made it bigger)
    My question is: is that carb salvageable or does it need totally replaced?
    Please help
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Picture?
    I have a carb somewhere with a broken needle still in place too..
  3. Simmy
    torqued too hard???
    Why were you tightening this?
    Screw it in until you find the bottom then initial setting is 2-1/2 turns out.
  4. dkavanagh
    Rochester, NY
    I'd look for a new carb body. Ebay, or @hogfiddles are good bets.
  5. Scott I
    Scott I Member
    wisconsin dells
    The beauty of screwing up is learning the new skills to fix your mistakes.
