I think i broke it
Discussion in 'XJ Technical Chat' started by Polock, Feb 22, 2019.
  1. Polock
    last month i wanted to add some oil but the seat latch was stuck, no problem so far. i just let the air out of the tires and lifted the seat, turned the fuses 180 and checked the oil again, just right. but now i can't seem to find where i put that tire air. so can i put any tire air in it or should i wait for the yamaha air to come back?
    oh, and is it normal for this thing to pop out of reverse as soon as the side stand goes in? and yes the battery is black.
    thanks
  2. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    Am I as confused as everybody else here?
    Letting air out of the tires will definitely lower the seat height, so I follow your logic here. Indeed the fuses should fit in either direction so there should be no harm in rotating them 180 degrees.
    Unfortunately, as soon as you set your original (OEM I’m guessing?) tire air free, it mingled with your local “every day” air and there’s no way to get your original air back in the tires. I recommend an air upgrade…
    I prefer Perri-Air. Mine came with a bonus can of shaving cream.
    It is Princess Vespa Approved.
    MattiThundrrr and SpearChucker like this.
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    It depends on the weather you'll be riding in...you dont want summer air in there for the winter and vice versa. You may have to travel south for some summer air. Yes the reverse issue you mention is normal for all XJ's of any vintage. Even brand new ones.
    SpearChucker likes this.
  4. 1965soda
    1965soda Member
    South Dakota
    I think most, if not all of this is covered in the original owners manual. ;)
    BTW....that was hilarious!
  5. XJ550H
    I can not get my bike into reverse ... I used synthetic grease on the chain guide might that be my issue?
  6. Nuch
    Suffolk County, NY
    It might be... but let's remember that reverse is down and to the left, next to 2nd gear. Your reverse lock-out trigger might be faulty.
  7. Chitwood
    That's my problem! I kept trying to find reverse down and to the right! Silly me! Should have it sorted in no time
  8. XJ550H
    does your reverse work when going up hill stop then goes into reverse easy?
  9. Polock
    ever since i turned that fuse 180 my horn sucks and my grips are loose
  10. Polock
    that's it exactly, maybe i need a new clutch cable
  11. Chitwood
    If I sit on the bike backwards it works every time...
  12. SpearChucker
    SpearChucker Active Member
    Prince George, BC, Canada
    Winter will be over soon boys, I suggest more scotch and a touch of "spring air".
    Hats off to Polock! :)
  13. SpearChucker
    Gotta get me some Perri-Air
  14. Timbox
    LOL, I thought that someone had hacked Polock's handle...had to read a few more reply's... Yes cabin fever is setting in the snow belt areas.
  15. Nuch
    Suffolk County, NY
    It's not just the snow belt... Though I've been able to sneak out here and there...
    I'll also say that heated gloves have changed the game. Was too cheap to buy them for myself... Then they arrived as a gift!
  16. XJ550H
    damn I missed the snow belt that could be my problem... will have to adjust it
    getting another 6 inches of snow on sunday
    Jetfixer and Timbox like this.
  17. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    There's a finnagin pin above the muffer bearing you have to press.
  18. joejr2
    Santa Fe,NM
    I picked up a fart in a can at a flea market last summer. I keep it in my saddle bag in case I
    Run out of gas
  19. Nuch
    Suffolk County, NY
    Smart... and they weigh absolutely nothing.
  20. Polock
    I cleaned out my carbs today, all that's left is sugar and fat
  21. XJ550H
    so no bacon for a while?
  22. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Nothing like running on fumes
  23. Tim O
    Tim O Active Member
    Charlottesville, VA
    Willy: What the hell you need ball bearings for?
    Fletch: Awww, come on guys, it's so simple maybe you need a refresher course. [leans arm on hot engine part, then jumps away] Heyya! It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads, and I'm gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State.
    SpearChucker, jayrodoh and 1965soda like this.
  24. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    It's never too cold or wet to ride in Western Australia.
    Suck it up :p
    Timbox likes this.
  25. Polock
  26. Timbox
    Yep after the blizzard went through and I had to move snow and ice again....I am ready for SPRING...pls Warmer temps would be a good enough tease for me.
  27. Jetfixer
    Forgot to grease the muffler bearings and to adjust the knutervalve ....and the 12 stage phetzervalve with 30w ball bearings.
  28. Simmy
    I think i broke it
    A more appropriate title "I think I smoked it" and from the chain of posts, obviously smoked more than just one.
  29. Nuch
    Suffolk County, NY
    Yes... But It would have to be posted in the Hangout Lounge not in the XJ Technical Chat.
    Chitwood likes this.
  30. Polock
    could i turn my wheel bearings over and use the other side?
  31. Tim O
    Tim O Active Member
    Charlottesville, VA
    Only if you use the proper "relative bearing grease"
