I want to change tenssioner gasket.
Discussion in 'XJ Technical Chat' started by amiel1157, Dec 11, 2018.
  1. amiel1157
    amiel1157 Member
    Philippines
    Hi my xj650 has the non self adjusting tenssioner. Can i just align the "C" then just remove the 2 bolts holding the tensioner in place??
    This would be my 1st time to adjust and replace the gasket and O ring in the tensioner, im not sure if im missing something. I surely dont want anything inside to get damage or mis aligned.. any thought?
    Is the gasket leaking?
  3. amiel1157
    amiel1157 Member
    Philippines
    Yes specially after long ride.. i already replace oring in the lock nut...
    OK.
    You can set the crankshaft to C and just remove and replace.
    You migh want o have a really close look at why it is leaking, and if the leak reallu is from there. That gasket is an unusual one to have fail.
    amiel1157 likes this.
